Have found a pair of rear fenders for my Studebaker. They where modified here in Sweden in the late 60's. Toughts and comment are welcome. Plan is to buy and use them. Have a couple of Wheel-setups for it
I prefer the stock wheel openings, but with 2 sets of quarters, I would run both and switch it up if i got bored.
If you use the big opening fenders, in my opinion the car needs to be much lower to make the tires fit the big opening.
To me, the big wheel opening at about the 10 o'clock position doesn't have a really pleasing shape. Also it seems a little too close to the top of the quarter panel. I would personally stick to the factory openings. Love the car though.
Impossible to say unless we know what you are building. I like the stock openings better. But if you were going for a sports car look with wire wheels, or a drag car with slicks, the big openings would work.
While I like the OEM fender opening better, when you paint the car...paint the "opened" fenders too..! That way you an swap back and forth at will..! Looks like they were done fairly well from your picture. Mike
Will build it little as a 60's Swedish custom ser where it takes it. Has a 30-35 years old custombuildt frontend for it to . I Like tires with lot of rubber and hight. Here is a picture of the front
You could also fix those red quarter panel openings with a different opening. Just cut out the extra large part and then weld in new openings. Still different than stock, but not as huge or tall of an opening.
