Projects Just picked up a 53 dodge cornet
Discussion in 'The Hokey Ass Message Board' started by martin53, Apr 8, 2018.
  1. martin53
    martin53
    Just picked up a 1953 dodge cornet. Would anyone out there happen to have a wiring diagram. The motor truns over but need to know what wires hooked up to the coil on the original 6 volt system. Also has the original 241 hemi.
  2. Los_Control
    Los_Control
    from TX
    original is 6 volt positive ground, from the switch it should go to the - side of coil and + side goes to distributor.
    Search this site for more great info on that car.
    http://p15-d24.com/discover/
  3. Rusty O'Toole
    Rusty O'Toole
    Don't have one handy for a 53 Dodge but here is one for a 1950 Chrysler. Should be similar, as both used the same 6v - ground system and electrically controlled transmission if it is the semi automatic. 1950 Chrysler wiring diagram.jpg
    martin53 likes this.
  4. Rusty O'Toole
    Rusty O'Toole
    To get it running all you need is a wire from the battery to the coil + from the battery+. If you have a wire with a couple of alligator clips it's easy. To shut off just disconnect the wire from the battery.
    firstinsteele likes this.
  5. It's Coronet...
    Peanut 1959 and 31Dodger like this.
  6. Rusty O'Toole
    Rusty O'Toole
    Manual trans or fluid drive?
  7. martin53
    martin53
    Manual trans. 3 on the column
  8. Rusty O'Toole
    Rusty O'Toole
    So, there should be one wire from key switch to coil and one from coil to distributor. That's it. If key not working a jumper to coil will do.
  9. 49ratfink
    49ratfink
    we need pictures or you are just making the whole thing up.
    blowby, spurgeonforge and wvenfield like this.
  10. martin53
    martin53
  11. martin53
    martin53
  12. martin53
    martin53
    I got it to turn over and finally got spark but my battery died. What would it take to switch to a 12v system.
  13. 49ratfink likes this.
  14. Los_Control
    Los_Control
    from TX
    you can use a 12 volt battery to start it, do not turn on any accessories like radio, lights, wipers etc ...
    Just the starter and ignition off the 12 volt battery and will not hurt anything.
    chryslerfan55 and 49ratfink like this.
  15. Atwater Mike
    Atwater Mike
    POSITIVE ground, Rusty...so 'hot' wire to coil goes to the negative (-) side, + side to dist. Backwards to our conventional systems...
  16. Los_Control
    Los_Control
    from TX
    You are braver then I, to correct Rusty :D
  17. Rusty O'Toole
    Rusty O'Toole
    Still, he is correct, and I am the jackass. I should know about - ground systems having worked on so many of them.
    It is also correct that you can use a 12v battery to test start. Don't let it run for more than 15 minutes or the coil can overheat.
    As for changing to 12V it is much easier to keep the 6v system and fix whatever is wrong with it. Wait till you get it running to evaluate what the car needs.
    chryslerfan55 and martin53 like this.
  18. nice car...what was said.....12 volts won't hurt on start up....might just help
  19. martin53
    martin53
    S
    O when using the 12 v battery. So use the post backwards. Positive to negative of co
    Thanks. I boosted the 6volt battery and thew some gas in the car and it started right up. I think I might keep the 6v till I can get everything together to switch it over to 12v thanks for the help
    Peanut 1959 and chryslerfan55 like this.
  20. Los_Control
    Los_Control
    from TX
    That is best advice of the thread. I already know that I am switching mine to 12 volt negative ground.
    Main reason is for a old flathead 6 I need a tach for freeway. I want a radio/cd player and will plug my phone in for gps.
    But 6 volt is a very reliable system.
    No need for 12 volt just because others have it.
    I suggested running the hot wire from ignition to - side of coil first and your reply had me wondering if I was right .... far as I know, it would actually start and run no matter which side of coil you connect to, just not run good.
  21. Rusty O'Toole
    Rusty O'Toole
    Go ahead and change it to 12v if you want to. I did a few in my younger days. Then I figured out it was a waste of time and money. Now I keep the 6v system and fix what's wrong. Easier and cheaper than changing to 12v and then fixing what was wrong in the first place.
  22. 49ratfink
    49ratfink
    ..that's a good lookin' car right there!
  23. martin53
    martin53
    Thanks
  24. martin53
    martin53
    I was surprised to see that the car still runs and everything in the car still lights up. Radio and heater work too. I just need to figure out the wiring. There are a couple of wires still hanging. I gotta find a wiring diagram. Thanks for the heads eveyonev.
