Art & Inspiration Led flourecents
Discussion in 'The Hokey Ass Message Board' started by Ghost28, Feb 16, 2018.
  1. Jeff J
    Jeff J
    Let me know just up the road from ya ! Come and see mine you'll be surprised !
    Turbo26T, Budget36 and lothiandon1940 like this.
  2. Jeff J
    Jeff J
    They take Milli amps to run Almost nothing !
    lothiandon1940 likes this.
  3. A generous gesture,thank you. HRP
    gimpyshotrods likes this.
  4. Ghost28
    Ghost28
    Cactus the truck is a customers that fell off a jack, and I have been straightening out the screwups. On the lights I did not replace the fixtures, I just removed the balasts from them and did a quick rewire. The lights were about 10.00 each. cost about 240.00 to do it, but I am so much less in the dark. Hell my welding skills might come back.
  5. Ghost28
    Ghost28
    Oh and the lights don't have that annoying buzz that fluorecents have.
  6. Jalopy Joker
    Jalopy Joker
    have your buddies over for pizza and beer, to be served after lights redone
    gimpyshotrods and Stogy like this.
  7. Mr48chev
    I have been buying the 4 foot complete units at Costco when they have them on sale for about 20.00.
    Sent from my VS988 using The H.A.M.B. mobile app
  8. OK,I'm confused,I looked at the site you posted,are these bulbs used with the old florescent fixture? HRP
    Texas57 likes this.
  9. upspirate
    upspirate
    They are, but you have to re-wire the "tombstones", or replace one/cut the the wires off the other and disconnect and /or remove the ballast
    belair likes this.
  10. upspirate
    upspirate
    They also make some that just replace the tubes, but I can't see using that type with a ballast even though they are easier to install
  11. Do you still use two bulbs? HRP
  12. belair
    belair
    I found that one led bulb was equal to two flourescent bulbs. And get the kind that don't need the ballast. Only one end of the bulb gets electricity, the other end is just to hold the bulb in the fixture.
  13. gimpyshotrods
    gimpyshotrods
    Yes. Same fixture. Disconnect the ballast and bypass. Install bulbs.
    That saves you coin.
    Sent from my SM-G900T using The H.A.M.B. mobile app
  14. gimpyshotrods
    gimpyshotrods
    Yup, up to you if you use two.
  15. Ghost28
    Ghost28
    If one bulb goes out in the 4 foot fixture the other bulb continues to work.
  16. Thank you, that would be something I can do,I was thinking I would have to take the florescent light fixtures down and put up new fixtures.
    Eliminating the ballast and replacing bulbs will be lot less expensive. HRP
  17. Early Ironman
    Early Ironman
    I ordered a case of 22 4 foot LED bulbs from Amazon. One bulb was broken from shipping. So I called them to replace that one bulb. They said they would refund the 160.00 I paid for the case if I ordered another case.
    So I happily did plus a single bulb to replace the broken one. Now my shop and my garage are really bright![​IMG]
    belair and gimpyshotrods like this.
  18. Ghost28
    Ghost28
    The bulbs I used are from a company called forest lighting,
    model# fl-t8u441-15-bn
  19. gimpyshotrods
    gimpyshotrods
    Damn. I hope that they break one of my bulbs!
    lothiandon1940 and Early Ironman like this.
  20. upspirate
    upspirate
    I just ordered some of the ones Gimpy listed.....figured that project has been kicked around long enough.....no overhead lights in the kitchen now for a couple of years!
    Prices have come down since I first looked into them too
    Early Ironman likes this.
  21. Hollywood-East
    Hollywood-East
    Best thing I've done in my shop in 20 yrs., I went from two smoked balist an half a dozen dead bulbs, To unbelievable light, $175.00 (20 bulbs)shipped off that "E" site, Everyone of my "old" buddy's an young have changed out... Best thing You can do!!! KIMG2013.JPG
    I left those damn balist Rite there, an rewired existing with existing wire in light fyi...Need white at one end, black at other.. mine were one pin at each end
    Stogy and Early Ironman like this.
  22. vickckik
    vickckik
    I got my 4 ft led tubes from Amazon. 6 tubes for about $6 each. After removing the ballasts from my fluorescent fixtures, I rearranged the wiring to a simple 2 wire configuration. Instructions on Youtube. Amazing brightness, no hum.
    57 Fargo and Early Ironman like this.
  23. 31Apickup
    31Apickup
    I replaced the lights in my garage with these LED Feit brand fixtures from Costco, made a huge difference.
  24. Hollywood-East
    Hollywood-East
    But.... I did leave a fluorescent in my "office" area for ambiance KIMG2015.JPG .. h-hee, That would have been the 21 one I needed, but.. keeping with tradition..
  25. Stogy
    Stogy
    Hollywood you better get something to eat your looking a bit skinny over there beside the Hotrod...:D...Now if you hadn't of put the new lighting in I might not have noticed...
  26. GTS225
    GTS225
    Hey, guys! Check with your local power company about any energy rebates that could offset the initial cost of those LED lamps.
    Might just make it REAL attractive to get it done.
    Roger
    56don and lothiandon1940 like this.
  27. Slopok
    Slopok
    Danny, If your old fixtures used T-8 bulbs, Home Depot has Phillips 4ft. bulbs that simply install with the original ballast. So easy a caveman can do it, just replace the bulbs. Instant on and no noise even in cold weather. Now it's like a tanning spa in there!:cool: Cheaper by the case.
    brad2v and lothiandon1940 like this.
  28. jetnow1
    jetnow1
    from CT
    1. A-D Truckers
    I put 15 of the Costco ones downstairs in my garage, and 5 in the attic storage area. Garage is 24 by 30
    so it is bright, especially with the semi gloss white walls/ white ceiling. I can finally see what I am doing
    wrong.
  29. Jeff J
    Jeff J
    These are the lights laying on the lift by my tires ! There about 1 1/2" wide and about 1 3/4" tall Replaced the old fixtures with this whole unit ! $25.00 each They can be butted together to run a long line of them .As in my last post
  30. I recently bought just one to see if there was much difference. Wow, that one puts out more than the other three next to it.
    I am sold, but this one was expensive at 50 bucks. So I need to check out other sources.
    Spooner Clinton likes this.
