Projects '33 5W Jalopy Rebuild
Discussion in 'Traditional Hot Rods' started by Shaun1162, Dec 27, 2016.
  1. Shaun1162
    Shaun1162
    Forgive the "stencils"... Trying to figure out if I should make the number straight with the body line, or leave it crooked- liked they've been for the last 50 years... My second attempt at numbering. Should be fun.
  2. Man the car looks great! I love the shot with the body off. So cool! Sorry about the race. Not Troggy enough I guess? Sure was a great motivator though!
    Shaun1162 likes this.
  3. onekoolkat1950
    onekoolkat1950
  4. catdad49
    catdad49
    Guess you made it Too nice. Just remember, the only person you have to please is yourself! I think the numbers should be staggered like they were, but that's just me. I think you have done the car Proud, Carp
    slv63 and Shaun1162 like this.
  5. Well done, trog or no trog. I love the "before and afters" at the beginning of your thread. I'll bet that car could tell some stories.
  6. Shaun1162
    Shaun1162
    Ha thanks man- it did help speed things along. Reason they gave was that it was a "dirt track car and they are a drag type race". They might take a look at it again, but I'm not getting my hopes up.
    Thanks man, looking forward to seeing your single seater up and running!
    I appreciate the kind words. I'm satisfied with how things are progressing with the car, and now that the pressure is off, I don't have to worry about rushing it. I'm leaning the same on staggered numbers- everything else on the car is crooked, those might as well be too.
    Ha you're definitely right, this thing has seen some action- even since I've owned it. Supposedly one night at a track in VT it drove over the bank and ended up out in the cornfield- guy said it took a while to get all the corn stalks out of it. Thanks for compliments.
  7. Nocero
    Nocero
    Just found this build or rebuild i should say.
    I read your other two build threads and the first one on this car any updates on the other two projects?
  8. Shaun1162
    Shaun1162
    Thought I'd share a little progress...
  9. Shaun1162
    Shaun1162
    Hopefully this little rig will be receiving a new mill by spring time. After 5+ years, acquiring 5 different flatheads, and dealing with a bunch of headaches with each, it looks like I've finally got enough to build a decent flatty.
    I picked up an 8BA block at an estate sale for $100 (only bid). Fresh back from the machine shop (the day before the auction), looks like it was mag'ed, 4 sleeves, and the rest cleaned up. Already drilled for adjustable lifters.
    The crank is coming from an engine that I traded a couple pieces of ductwork for. The car had sat in a swamp, and after the oilpan rotted out, the engine was invaded by about 10,000 ants. But after cleaning it out, robbing the pistons for another flathead, and using the block for a coffee table, I found that the crank was freshly turned .020. Currently polishing it a little, and trying to find someone to balance the rotating assembly.
  10. greaser
    greaser
    Big change with bottom body panels. Looks awesome.
  11. Pete
    Pete
    Yea man, what a difference .
  12. wheeldog57
    wheeldog57
  13. weps
    weps
    from auburn,IN
    Those bottom pieces are WELL WORTH your time to fab and install!
    really helps the look (and value) of the car
    48fordnut and Shaun1162 like this.
  14. adam401
    adam401
    Wow your coupe looks tough as nails! Awesome!
  15. Runnin shine
    Runnin shine
    Who would’ve thought six inches would make such a difference down there?
    That’s what she....
    I’ve been hoping from the start you would add patches at some point.
    Awesome!
    kidcampbell71 and Shaun1162 like this.
  16. Hell of a good job Shaun.
    18n57 and Shaun1162 like this.
  17. JimmyD3234
    JimmyD3234
    from PA
    KOOL I like it WOW looking good :cool: :cool:
  18. Shaun1162
    Shaun1162
    Big (bore) update coming on the mill for this machine... Until then, does anyone recognize these Offy heads? Can’t say I’ve ever seen ones with water outlet like these:
  19. patmanta
    patmanta
    from Woburn, MA
    1. MASSACHUSETTS HAMB
    I would be inclined to say they're intended for late blocks, 8BA/EAB. They probably had their own water necks or were meant to put the stock necks at a different angle to clear something.
  20. 48fordnut
    48fordnut
    Awesome build . TROG's loss not yours. You have done a great job getting the car looking right. That grill is the tits.
  21. Shaun1162
    Shaun1162
    Anyone an expert on flathead valvetrains?
    The two big bores I acquired are set up for the beveled adjustable lifters on the left. Regular adjustable on the right.
    From what I can find, I believe they’re Weber? Or maybe Isky?
  22. 3blapcam
    3blapcam
    That's cool as shit! I bet Bored & Stroked has input... hit him up.
    3blap.
    Runnin shine and Shaun1162 like this.
  23. GMC BUBBA
    GMC BUBBA
    Looking good, i guess i bettter finish that other ignition system for the new motor. Do you also need a Mallory coil for it too...
  24. Shaun1162
    Shaun1162
    I think this intake valve is slightly bigger than stock...
  25. Ralph Moore
    Ralph Moore
    The slotted lifters were pinned to prevent them from rotating.
  26. banjorear
    banjorear
    Yes, Isky and Weber and other companies offered these. You need to contact Cam Grinder Pete. He's may post here, but definitely posts on Fordbarn. He'll be able to hook you up with a cam and clips for those lifters.
  27. Shaun1162
    Shaun1162
    Some more progress.
    Cut out the inner door section from this donor I got from @cad-lasalle and test fit. Trying to figure out the best way to get the top of the door back into shape?
    Bit of an update on the mill for the coupe...
    Recently acquired two old school race flattys from a friend in VT. Disassembled, but mostly complete.
    This is the one I’ve decided to go with- 8BA, bore .125 over, ported, relieved, fresh offset ground Merc 4 1/8” crank. Plans are to finish it off with an Isky cam that was included, the Offy heads that were thrown in, and an old Edelbrock 3x2. And of course a fresh Mallory from @GMCBubba
    Chasin threads, waiting for the Bobcat to warm up and to move some more snow... And why yes, yes that is a snowdrift in the shop. Pretty much ready to move South haha.
  28. Glad I decided to read this thread. Awesome resurrection. Vast improvement in looks without detracting from the history. Now I wonder if some of the beat up old dirt trackers I've passed up were really missed opportunities.
    catdad49 and Shaun1162 like this.
  29. Shaun1162
    Shaun1162
    Cleaned up the old 3 ring Speedo-motive slugs and early rods. As you can see, everything was left apart for quite some time and covered in rust, grease, and grime. They cleaned up well, but I have hit a bit of a speed bump.
    Rods are a mixture of 21A and 91A’s. They appear to have been balanced, but aren’t marked so well. It appears I have a 1,2, a pair of 3’s, and a #4. Not so handy...
  30. GMC BUBBA
    GMC BUBBA
    Check when ya put them back on the crank , clearance good ??? RUN THEM !!!!!
    48fordnut and chryslerfan55 like this.
