Projects Pounding out a T roadster
Discussion in 'The Hokey Ass Message Board' started by justabeater37, Nov 22, 2017.
  1. You're killing it with the doors. I really like the method you used to make the inners. Not how i would have - your's is much simpler. Great job!
    sko_ford and loudbang like this.
  2. justabeater37
    justabeater37
    Hate the firewall mounted master cylinder but there is just isn’t much room for anything in this thing. Remade the front of the seat pan to clear the trans. The engine/trans may be able to drop a little but not much. Lowered the grille a half inch as I found a shorter radiator. Maybe I can get the chassis a little more together this weekend. Also a picture of he approximate driving position. F3FFABDC-6BA0-45B3-AF18-1B031B5EE033.jpeg 47D44687-6F53-45F3-8181-DAB5FF7AE912.jpeg 5F1B7E04-34E1-4CF2-8044-A06BA2062BDB.jpeg F945D199-959B-43BA-AFD4-B38F44C6DFD0.jpeg C19F67EB-9D25-42DF-9FB2-81EA9978B42A.jpeg C4DCEC24-648F-44FA-B578-05834CE2F82D.jpeg
    Tim, chryslerfan55, 32SEDAN and 12 others like this.
  3. Dick Stevens
    Dick Stevens
    That grille shell does need to come down to look right, needs to be lower than the cowl! Great metal work and you want to make sure that doesn't detract from the rest of your hard work.
  4. justabeater37
    justabeater37
    It runs down hill to the shell now. The driving position picture has a model A hood laying on it just for a length reference that day. As I am building this roadster to ultimately give it away for charity, budget is a concern. I need to use as many off the shelf parts as possible and a custom radiator would dig deep into the budget.
  5. justabeater37
    justabeater37
    This may be a better picture after lowering the grille. I may be able to take a little more out yet, and it definitely needs to get chopped. C3C04765-938E-4B48-B672-D8A67668F161.jpeg
    tb33anda3rd, bobwop, cactus1 and 5 others like this.
  6. justabeater37
    justabeater37
  7. justabeater37
    justabeater37
    A few of the pictures I saved for inspiration. These kind of show how hard it is to get around the optical illusion of the hood line running uphill If I could find a radiator around 20” high that would fit the grille shell it would make life a lot easier. Any suggestions? Inexpesively . 5D41A477-FF8D-4EF3-81D5-C285A00E3B8F.png 9AF855C9-67FA-47AF-B13F-E5101A7B0BA1.png 4BB3B7DF-73C4-44BD-9EEF-BBAA7E5DAEAC.png
    Tim, 32SEDAN, sko_ford and 4 others like this.
  8. mkebaird
    mkebaird
    Great car! T's are TINY, make great one-seaters. Not much room for pedals, good thing you've got the slush box.
  9. justabeater37
    justabeater37
    I’ve got 3 pedals in my 27. Tight fit even with that much room.
    Tim, Atwater Mike and loudbang like this.
  10. fleet-master
    fleet-master
    Your doing great !! Most guys wouldn't even try this level of project :)
    Atwater Mike, loudbang and Jimmy B like this.
  11. justabeater37
    justabeater37
    Long day at work and I didn’t feel like messing with it much tonight. So I just bent up the pieces for under the turtle deck to start fitting them and taping up the hood line a little better. The grille is actually 3/4” lower than the cowl. I think the angle on the doors magnifies the running uphill look. Ride height will be 2” lower than where it’s at right now. That’s as low as my jack stands would let me mock everything up. The banjo needs to make way for the 8”. If I was keeping this car, the banjo would stay. BBE5431C-C920-446D-BFF6-311623AD50AD.jpeg 31DB0703-09FC-4664-A37B-AC078EE455DE.jpeg A8DE217F-506F-4436-89AC-33BE70C95210.jpeg 63848DC6-78B9-4493-B18F-2544F80D96BC.jpeg
  12. Dick Stevens
    Dick Stevens
    Good on you for doing this for charity, that definitely affects decisions on parts usage for financial reasons! To my eyes it looks like the grille shell would look better if it was at least another inch lower, but I fully understand why you are doing it the way you are doing it.
    32SEDAN and loudbang like this.
  13. justabeater37
    justabeater37
    Here is the end of the story on the grille placement. This is the shortest radiator I could find. There is no more I can do to lower it anymore. I have modified the crossmember as much as I can to get the radiator as low as possible. There just isn’t anymore room short of a custom radiator. 0140CBA5-FA9B-43DA-8CDA-52870FB8DE46.jpeg 47D3A7B6-2CAC-4FC3-8DB6-98CA22324E2B.jpeg DE64ACB4-8AE4-4491-8C8D-34B8F939883C.jpeg 76E9211A-5E9A-40B8-93A5-10A94DF9BD99.jpeg 676A12C3-8E8E-404D-980C-B20C26E17247.jpeg
    bobwop, brEad, AndersF and 4 others like this.
  14. bobwop
    bobwop
    from Arley, AL
    I wish I had stock in the company making the tape
    leadfootloon, loudbang and verno30 like this.
  15. justabeater37
    justabeater37
    Sharpies would be a better investment. I haven't even used a whole roll of tape but my Sharpie collection seems to have wanted to dry up all at once. I am down to only about a half dozen good ones now.
  16. justabeater37
    justabeater37
    4 1/2” out of the grille makes much better proportions on the T. Cheated and used a Speedway insert already chopped saves time 5A6FCD50-396D-420C-A898-85396B041C16.jpeg 6E6B2DBB-1848-4C43-9CAF-875018109B01.jpeg
    A Boner, Tim, Dannerr and 5 others like this.
  17. Roadsir
    Roadsir
    I was searching EBAY looking for small radiator for my Dad's Modified project. Check out some of the tuner cars Fabbed aluminum radiators.....As an example the Acura/Civic 50mm (3 core radiator). Overall height is 18.1 inches, width and 14.7. The three core is only $65....A lot less for a 2 core. Inlet/outlet are correct for SBC. If the motor is mild it might be enough...
  18. justabeater37
    justabeater37
    All I could find were 1 1/4 hoses. I will keep looking but likely going to run the radiator I have as it’s here and paid for Thanks for the tip for future reference.
  19. Król
    Król
    Fantastic metal working skills!
  20. When I built my ‘26 track roadster pickup I made a plywood pattern of the space claim for a radiator. Drew dotted lines defining the maximum height for each tank and where the hose bibs and fill neck needed to be. Took it to my local radiator guy and turned him loose...and he made it out of brass. It cooled the Nova 4 cyl. fine and probably would have done a small small block.
    I do recognize that local radiator shops up to the task, or not even up to it are getting scarce almost everywhere.
  21. justabeater37
    justabeater37
    I forgot the before pictures, but spent a little time today straightening some model A hood louvers to cut down for hood sides. Not perfect, but way cheaper than another set of hood sides. EBC5A1EC-1AD1-4445-B281-B26C71DE1E5D.jpeg 759BA8A1-103F-4959-8D4B-A7D43066B48C.jpeg A766E01F-0AB2-4267-9BBE-9BAEE4E03883.jpeg
    Tim, brEad, loudbang and 2 others like this.
  22. justabeater37
    justabeater37
    Also spent some time rolling a bead around the turtle deck like was stock. Now I have to fix the rest. F4C7995C-5ABF-49A6-859E-3684A48A5A9B.jpeg
  23. I need to check in to the hamb more often. This is a killer T
    kidcampbell71 and loudbang like this.
  24. justabeater37
    justabeater37
    It's justabeater 23... I really hope I can live up to everyone's expectations for this car. Starting to second guess whether I should have posted this up here for scrutiny or not.
    verno30 and loudbang like this.
  25. Roothawg
    Roothawg
    Why? You could quit right now and still be in the top 10 for tech threads.
  26. justabeater37
    justabeater37
    I am a pessimist/perfectionist. Nothing is good enough no matter what anyone says. I hate it, but that's who I am. I fight it every day. 40+ years of never seeing the positive in a compliment. As this car is being built for charity, there is a very solid deadline of May 4th to get this done. Starting to feel the heat now. I also am funding this all out of my own pocket as several donations have fallen through. That means my own projects are on hold for a while.
  27. manyolcars
    manyolcars
    Dont bother Howells. Buy your Howell parts from Snyders. You will get real people quickly, great service, prompt delivery and returns if needed
    GuyW likes this.
  28. justabeater37
    justabeater37
    Not much for progress but finished up getting the bead around the Turtledeck B5203E7A-7BD9-408F-9FE9-3B4BAC358886.jpeg 7AF2D0FB-56B1-4977-9C02-2A17C39E0938.jpeg . I wish I would’ve decided to do this in the beginning instead of after the fact. The fiberglass body did not have that bead, but if it’s going to be steel it may as will be closer to stock right?
    Tim, Atwater Mike, Dannerr and 5 others like this.
  29. manyolcars
    manyolcars
    you are doing awesome work
  30. justabeater37
    justabeater37
    Thanks, I need to get my welding skills better so I can end up with a nicer end product. I am thinking of taking some classes next year to try to figure out the errors in my ways.
    tomschev2, blackjack and brEad like this.
