Technical 8ba flathead
Discussion in 'The Hokey Ass Message Board' started by ButlerRod&Metal, Dec 9, 2017.
  1. ButlerRod&Metal
    ButlerRod&Metal
    from Butler,PA
  2. fordf1trucknut
    fordf1trucknut
    I did most of my own work and tried to save as much cash as I could and I ended up with around 4k in rebuilding my 4" stroke 0.060 over 8ba flathead. They are NOT cheap to rebuild.
    Unfortunately around here in western pa... Probably 1 out of every 2 blocks that I came across are cracked across the exhaust valve seat into the cylinder in the center....even 2 motors that I heard run before buying!!!!!.. So you may buy a few engines to get a useable core. So if the head is off an engine look it over really well before you buy.
    Ps. I know the guy with the v8 60..... He is a super nice guy......... ha ha. As as much as I would love to sell the v8 60. It really is best for a light car.
  3. ButlerRod&Metal
    ButlerRod&Metal
    from Butler,PA
    Yea he seems like a pretty good guy lol. I liked the v860 cause it’s odd and you don’t see them very often. Also like someone else posted. The size of them is just about perfect.
  4. fordf1trucknut
    fordf1trucknut
    What kinda car are you building?
  5. ButlerRod&Metal
    ButlerRod&Metal
    from Butler,PA
    31 Tudor sedan.
  6. tubman
    tubman
    About V8-60's. I had one long ago as kind of a novelty in the shop. I friend of mine knew about it, so when he saw an ad for one at a local auction, he told me about it. It looked to be fairly complete (with transmission), but it was very crusty and locked up. I thought "What the hell", and tossed out a bid. In the final analysis, I dropped out at $200 and the engine went for $860 (not including buyer's premium).
  7. sportster-bob
    sportster-bob
    Patience and willingness to drive some distance is whats required to get you a much better deal. I have two 8B motors and one 59AB in my garage now that I did not pay over $150 for any one of them. Granted they don't always come with all the parts still attached but some do. I'm watching another right now for $250 that looks to be complete. I bought mine fully aware they may only be good for parts and as a leaning tool for disassembly but they are out there. Ford built a lot of these over the years so keep looking and stay away from the guys that want 2-3 K for an old engine that needs rebuilding.
    Also agree you should forget the block with a hole and the V8-60. It's too small of a motor for your '31 and you'll likely regret the money spent and low power result.
    Spread out your search range and keep looking for a better deal.
  8. 1930 turbo
    1930 turbo
    from pa.
    I see you live in Butler,Pa. Lots of hills down there. The V8-60 wont like the hills! I live in Corry,Pa. My son and I put a 60 in a 28 highboy roadster . It didnt pull hills till we went to 4:44 gears and a turbocharger. When the 60 blew a piston, we changed to an 8BA. Now it goes up any hill around easy.
  9. ButlerRod&Metal
    ButlerRod&Metal
    from Butler,PA
    Thanks for al the advice guys. Going to check out a few this weekend I think and see what I come up with. I also haven’t even started the chassis for this car yet. Just trying to get all my ducks in a row so I’m not waiting around on parts come time to needing them.
  10. Bandit Billy
    Bandit Billy
    I bought my 8BA before I had a frame or a body...or a brain according to Mrs. BB. No regrets to the order I chose. Good luck with your build!
    ButlerRod&Metal likes this.
  11. Mr48chev
    Cool on finding some interesting potential project engines at more of a reasonable price.
    I keep seeing guys rave about old engines having "rebuilt tags" as if it was just rebuilt a few months ago. The engine on the other page was rebuilt November 3, 1964 Just over 53 years ago and probably was worn out again in the early 80's or earlier. The tag just tells you that that particular engine was .030 over and had a 10-10 crank in it. It does not mean that it is a somewhat fresh engine that won't need a complete rebuild again but should be looked at as an engine that does need a complete rebuild.
    On flathead costs, I picked up a complete ran when we pulled it 8BA a few years ago for 400 for my Model A and that was the price I offered, might have got it for a lot less than that if I had played my cards a bit better but I knew the history of the engine pretty well. As others said they aren't cheap to play with and you really have to want to run one and not just because the cool guys have them.
  12. ButlerRod&Metal
    ButlerRod&Metal
    from Butler,PA
    I think the rebuild tag helps with knowing for sure what was done to the engine so your not just taking a guys word for a rebuild.
    Yea they seem to be quite a commitment to make for your car. I have two small blocks sitting in my garage and two y blocks. But every time I tell myself I’m using one of them I just can’t picture that car being complete without a flathead. I haven’t broken the news to the ole lady yet that we’ll have to eat ramen noodles for the next year so I can finish this car, but I’m sure she won’t mind
  13. av8
    av8
    Overall, the late block (8BA) is a better choice for a real-world day-to-day engine. The cooling system is far better than the early scheme (so long as you don't screw it up with early center-outlet heads).
    The absence of a dedicated bell housing lets you adapt any transmission you want without a lot of fuss; the cast-iron adapter used for truck engines neatly accommodates the early Ford trans, as well as a number of adapters, and the stamped steel bell housing used in passenger cars has the familiar four-bolt pattern common to decades of modern three- , four- , and five-speed manual boxes.
    Crankcase breathing is improved with the late engine, so long as you use an intake manifold that accepts a road-draft tube.
    While the bevel-drive distributor isn't as cool looking as the diver's helmet plugged onto the front of the block, it's much easier to live with. Just forego the original for a modern unit with full vacuum or electronic spark management. And you'll save yourself some problems in locating a cooling fan.
    Just some things to think about . . .
  14. 1946caddy
    1946caddy
    from washington
  15. paintman27
    paintman27
    from new jersey
  16. paintman27
    paintman27
    from new jersey
  17. paintman27
    paintman27
    from new jersey
  18. ButlerRod&Metal
    ButlerRod&Metal
    from Butler,PA
  19. IMG_0297.JPG Having owned over 30 v8 flatmotors over a 55 year period,I never pay more than $100 for a block.Many sellers will say it runs; so what, they (engines) can still be cracked and run. I get $300 for a bare block and offer full return on your monies(30 days) if you find a crack that makes the engine NOT Buildable. Flatheads Forever!
    SquintBoy likes this.
  20. ButlerRod&Metal
    ButlerRod&Metal
    from Butler,PA
    That’s what I’m looking for. All the ones I’ve looked at have been together and nobody would come down on price since I could look for cracks. I think most people that get a flathead that don’t know about them google it and then price it according to what they see running engines go for and figure they’re sitting on a gold mine and won’t budge.
    Finding a knowledgeable guy like you that understands the problems with these motors is what newbies like me need to do so we don’t end up with the cracked blocks laying in the garage before we get a good one.
    If you got a spare laying around chuck that thing in a box and ship her my way. I’d be glad to pay 300 for a block I Know isn’t cracked.
  21. ButlerRod&Metal
    ButlerRod&Metal
    from Butler,PA
    This is the type of info I need. I can read all the articles I want on line. But when it comes down to it the guys with the engines give the best advice.
  22. 59Apachegail
    59Apachegail
    from New York
