  1. 50 Plymouth tudor wagon,...
  2. Thanks Rusty!
  3. When I die, I want to come back as a piece of stainless.
    pat59, stillrunners and Bowtie Coupe like this.
  4. pcbart
    pcbart
    from NC
    More likely a shotgun
    czuch and Bowtie Coupe like this.
  5. Leakie
    Leakie
    Air wrench
  6. egads
    egads
    That was no shotgun!
  7. KRB52
    KRB52
    from Conneticut
    Most likely, multiple times over the years. Once the first shot is marked on it, any more come a lot easier.
  8. Yep..Squablow...went to look at a few about a dozen - tri 5 Chevies a roundy round guy had on his property....all on the their sides - with their frames cut off....for the dirt track cars.....one was turned back over and the trim had just fell off....sad...there were some post cars there....
  9. Los_Control
    Los_Control
    from TX
  10. I have the hood that '40 Ford truck is missing as a cover over my air compressor.
  11. Los_Control
    Los_Control
    from TX
    hoping I dont get in trouble for posting that photo, Is actually a model the guy created. Has a 1957 2 door hard top that looks more real then the truck. I know nothing about them, but thought they were pretty cool looking and fit this thread.
    I do not even know if they are plastic models or metal.
    czuch and Ron Funkhouser like this.
  12. Pretty realistic until you look at it closely.
    Spooky likes this.
  13. BJR
    BJR
    Is that a 9 volt battery under the front of it?
  14. Spex84
    Spex84
    from Canada
    Wow, if it wasn't for the hood hinge slots, depth of focus, and upon close inspection, birch catkins to represent leaves, I mighta been fooled. A very cool model.
  15. I thought that looked like a model the first time I saw it. I was wondering what kind of camera made it look like that, then reading further confirmed it. That was a good job.
    czuch likes this.
  16. 117harv
    117harv
  17. t-rod
    t-rod
    Merry Christmas![​IMG]
    Bad decisions make good stories.
  18. scotts52
    scotts52
  19. 41 C28
    41 C28
  20. 40LUV
    40LUV
    from Mid Jersey
    Saw these in Key West. They were props at different restaurants. 100_0996.jpg 100_0998.jpg
  21. the 4 wheel drive is a genie 66 60 thru 66 trucks 013.JPG 60 thru 66 trucks 026.JPG chevy chassis. it has a divorced transfer case with high and low range.
  22. low budget
    low budget
    from Central Ky
    Looks like a customized gas tank and gas door to isnt it? Looks like someone did a good job from here.
  23. Yea but now the gas tank is in the cab behind the seat like its supposed to be. The cab came off my old 64 3/4 ton that I used for a wrecker. I plant to put the wrecker bed on the 4 wheel drive. Ive got some C60 fenders and 60 chrome grille. the big truck fenders will easily clear the 19.5 wheels and tires I have for it.
    chryslerfan55 and low budget like this.
  24. mlake01
    mlake01
    Where I grew up 50 years ago, way out in the country, and the son of a 50’s hot-rodder; we had quite a few old cars around - parked out in the trees after having given up whatever organ donation they were purchased for. About 100 yards from the house, you could see the back of a 35 Ford 4-door sedan poking out of the brush, with that cute rear window nicely visible and all.
    I’m pretty ashamed to admit this, but I must have put 300 holes in that thing with my little Browning lever action.22. It was just far enough away that you could hear the bullet impact - crack, plink!
    Later, my Dad and my Uncle used our D4 Cat to smash it flat and bury it in the creek bank where the water was eroding away the edge of the field.
    I remember that car being pretty nice - had all of its fenders, doors, running boards, etc. Dad said he paid $40 for it because the tires on it were better than the ones he had at the time.
    What we could do with a time machine!
  25. stationWAGONS
    stationWAGONS
    from Vegas
    We found/saved this one.
    A 1949 3800 LWB (DELUXE!) panel.
    It was put on a rotisserie and that is luckily as far as the last owner got.
    It's the driest one I have seen. all there, just disassembled.
    Technically it was "hanging and rotting"...
    Luckily the guy who sold it to me was a big help and put it back together.
  26. stationWAGONS
    stationWAGONS
    from Vegas
    Also I was able to save this one...parked since '89 and low miles...so it's not rotting
    getting a "CLR" restoration
  27. stanlow69
    stanlow69
  28. stationWAGONS
    stationWAGONS
    from Vegas
    postOLDSinTREES.jpg Got to walk through an actual hoarder's property. The family has been there since the 1800s and most of the cars were family cars, parked when they were done with them.
    I will get organized and post some. The grove of trees grew up around them
