Technical 1939 Ford Pickup SBC vs SBF
Discussion in 'Traditional Hot Rods' started by The37Kid, Nov 2, 2017.
  1. The37Kid
    The37Kid
    I know the HAMB era ends in 1965, and I'm fine with that, my '39 Ford pickup project will be right there. I got a really good deal on a SBC & 5speed, but really would rather have a 289 and a Ford top loader. For the guys that have installed both, are they both an easy fit, or is there firewall cutting? Thanks, photos are always good to look at.
    Bob
    Dino 64 likes this.
  2. slim38
    slim38
    from Sudan TX
    1. H.A.M.B. Chapel
    Im sure youll have to cut firewall. My 38 has flathead in it still and it doesn't have any room between firewall and motor. There are some reads about it on here and a 38-39 club also.
  3. Chiss
    Chiss
    from S.C.
    x2 on the rather have, Go with your Gut............
  4. Rustygt
    Rustygt
    from Emeryville
    You can go with the ford in a ford, my vote !! Just install a Bronco rear sump oil pan, check the distance from the rear of the motor to the radiator. I will change my 41 soon, 302 with a C4 yeah baby !! It has a small block chebby came that way. :(
    droppedstepside likes this.
  5. 56sedandelivery
    56sedandelivery
    I'm a "Chevrolet guy", but I'd go with the Ford into Ford also. Distributor's in the front, engine is narrower, and it sounds like that's what you want anyways. I am Butch/56sedandelivery.
    droppedstepside and LOU WELLS like this.
  6. I do not know if there is a lot of difference between a '39 and a '40 under the hood room. Here is a pic of a gm 350 in a '40 pickup I did 10 yrs. ago. Did not have to do anything to the firewall. There was a 1/2" clearance between the passenger side valve cover and the firewall and the dip stick for the 350 trans was a tight fit but it worked. hope this helps.
    EDIT: I did have to use an electric fan though as there was not enough room for a mechanical set-up.
    LOU WELLS likes this.
  7. MIKE STEWART
    MIKE STEWART
    I have put 302 SBF , 351-W and 351-c Boss and 429 Ford big block - and 327 Chevy in 1939 / 1940 Fords. Yes the ford engines are more work - requiring fire wall surgery and mustang IRS helps greatly. But I do have a 1939 dex. Coupe with straight axel and 351- w and 1.5 inch firewall set back . The 429 was a big fit. The Chevies fit easy - evaluate your fabrication skills. If low - do the Chevy.
  8. Pete Eastwood
    Pete Eastwood
    from california
    Put the Chevy in. Everything about it, fits better !
  9. sloppy jalopies
    sloppy jalopies
    DSCN1468.JPG everyone runs sbc's...
    step out into the sun, run a SBF the way god and henry intended...
  10. Look at the snow white shorty Ford water pump kit,it will help you gain 2 extra inches of much needed room when running a sbf. HRP
  11. The37Kid
    The37Kid
    Thanks for all the replies so far, the SBC and 5 Speed will wind up being free at the rate the extras are moving, in a perfect world someone would swap me even for a SBF and 4 Speed. Just remembering the 1965 era, Jim Clark winning INDY is a Lotus Ford, Ford GT40's finishing Le Mans 1,2,3, I'd be happier with the Ford under the hood of the '39.
    Bob
  12. barrnone50
    barrnone50
    from texas
    Ford in a Ford would be my choice..A perfect match.
    ChefMike and droppedstepside like this.
  13. i have a 302/c4 i will trade you.
    Clay Belt and studebaker46 like this.
  14. Bob Labla
    Bob Labla
    from mitten
    GEDC0833.JPG I have a 302 in my '40 pickup. I didn't have to do anything to the firewall. I used the Explorer water pump, timing cover and balancer (50OZ). Pusher electric fan, sealed against the radiator, works well.
  15. MIKE STEWART
    MIKE STEWART
    I saved this pic. Like it - Thanks
  16. MIKE STEWART
    MIKE STEWART
    One of my friends did use the Snow White water pump kit - 1939 Ford and 302 - did not cut the firewall with an puller electric fan.
  17. The37Kid
    The37Kid
    Today I'm thinking the SBC may be ok, I'd only have to open the hood to jump start it and check the oil.
  18. sloppy jalopies
    sloppy jalopies
    37 kid...
    I know what you mean... if I was stuck with a sbc under my hood I would only open it for a jump or to add oil...
  19. Dan E
    Dan E
    I installed a 5.0L out of a mustang with the T5 five speed. I did cheat by picking up a new frame form Boling Brothers Early Iron. I think Fords should go into Fords
  20. thunderbirdesq
    thunderbirdesq
    I’m no brand loyalist, I think it’s kinda silly... I put a 350 in my 41. I’m not certain, but I’d bet the engine compartment is pretty close in size to the 39. I was considering the 302 but having to buy different front drive accessories, oil pan, etc just for the sake of fordinaford turned me off. The Chevy fit right in with the only mod being replacing the x member center with two plates to accommodate the trans (th350), mechanical fan, etc. exhaust was a bit tight with the stock steering but I used a 60s c10 pass side ram horn manifold on the drivers side and trimmed the engine mount on the frame back a bit. I got the bolt in engine mount kit from a guy in the classified here (40ragtopdown) that makes them. nice stuff and very reasonable.
  21. PoTaToTrUcK
    PoTaToTrUcK
    If you are afraid to go fast, put in the Chev!
    ChefMike likes this.
  22. Definitely keep it all Ford. You won't have to open the hood to; jump it, put in oil, or change the name across the hood;).
  23. sloppy jalopies
    sloppy jalopies
    you know why they paint chebbies orange... so you don't trip on them in the woods...
  24. The37Kid
    The37Kid
    Well..................The SBC is something in a parts deal with a friend of 40+ years, and with the sell off of the other odds & ends just about free. Ted the local Chevy legend (tb33anda3rd) said go with the SBC, Pete Eastwood put one in his '25 T Ramp truck with a full hood, and Thunderbirdesq has one in his '40 delivery, he did a really nice job and dropped my '32 Heavy, but that is another story. CSRA Swap Meet was today, I told myself the small block decision would depend on finding a set of rocker covers. Found them.:) DSCF1735.JPG
    tb33anda3rd likes this.
  25. Blues4U
    Blues4U
    from So Cal
    I'd be more inclined to hide a SBF. They may run good, but they are not a good looking engine, and shoehorning them into an early Ford always looks a bit Rube Goldberg to me.
    Here's a SBF in what looks like a 39 Ford truck. I don't mean to demean the guys truck, but it's not an especially good looking engine, is it? Well, I guess these things are subjective, beauty is in the eye of the beholder after all.
    Anyway, I took the pics yesterday Bob, to post them here for you. Hope they help.
  26. Those headers and the wiring nest leave a lot to be desired. Like a Cheby Distributer hidden in the back.
  27. The37Kid
    The37Kid
    DSCF1761.JPG Well the Olds Rocket covers do fit, or will once adaptors for the screws are fabricated. Ran the numbers and it is a 327 , three years past the HAMB cutoff year, and I'm having second thoughts. What if this is worth more than I think it is? eBay sold prices make me wonder if flipping the engine & 5speed world be the smart thing and rebuild the SBF I've had for a few years. Bob
  28. 210sedan
    210sedan
    from upnorth,wi
    I started working on old ford in the early 70's
    back then you only did it one way.
    put the chevy in and be happy.
    and your old ford will be happy to.
    283john and scrap metal 48 like this.
  29. 210sedan
    210sedan
    from upnorth,wi
    who ever thought the SBC was to become the new flathead.GEE
    Fabulous50's and scrap metal 48 like this.
  30. goldmountain
    goldmountain
    Chevy. They look so pretty when you dress them up. You can get intakes for one to six carbs, blowers and whatever. Chrome oil pans, water pumps, timing covers, finned valve covers every which way, and cheap. With the Ford, you put on 4 Weber carbs, Cobra valve covers and oil pan and you have hit the limit, more or less. As far as to what is the better engine, it's a toss up; either one. If you want a pretty Ford engine, get a flathead. In any case, the Chevy gives you more bling for the buck.
    joel, 283john, TagMan and 1 other person like this.
