Hudson 232-262-308 engine tech
Discussion in 'The Hokey Ass Message Board' started by PacaRacer50, Dec 11, 2010.
  1. Hud I
    Hud I
    from Tennessee
    The manifold will fit anything from 48 up. The head could be narrow or wide. It is probably a wide block head but have to measure to be sure. I don't have the measurements off hand. It is for a 6 of course. I have a set for the wide block. The head I have has a crack but the manifold is excellent. All of the wide blocks are the same. 232-262-308 same block, wide, 51-54. narrow blocks were 232-262, 48-50. Hope this helps. Hud
  2. mr_cesco
    mr_cesco
    hey guys, I need help with a hudson engine, the seller send me this casting number 804639,
    he said the first 8 could also be a 3. I will be glad to have any kind of info about it.
    thanks
  3. Studegator
    Studegator
  4. mr_cesco
    mr_cesco
  5. Island Flats
    Island Flats
    Is there a plug anywhere in the block that can be removed to add a mechanical oil pressure gauge? I have a 55 308 and there are a few but I'm unsure if they are for oil or coolant.
  6. DRV13
    DRV13
  7. mddan
    mddan
    from Newark, DE
    I talked to Clifford Performance about a Hudson 2 x 2 manifold like what they make for other inline 6s. They said they had the design all done but stopped at the tooling phase due to cost and unsure interest in the market. He said if he could get a minimum of 6 full up dual manifolds w/ down draft Weber carbs setup (like this Jeep one: http://www.shop.cliffordperformance.net/Jeep-258-Twin-38-Weber-Fuel-Delivery-System-08-7001J-258.htm) they would move on the project. These would be the same price as the other makes $1,389 complete. Obviously, he would like to have more than that if possible. This would be usable on a stock engine. The Weber does a better job of atomizing fuel than most other carbs so it sprays into the plenum, not mixes. These systems would be jetted and ready to go as delivered. Yes it is more money but with the price of a stock Twin H going up and up this is not all that out of line. Anyone interested?
    Island Flats likes this.
  8. esfoder
    esfoder
    from Oregon
    I would be
    Dusty
  9. mossback44
    mossback44
    I realize that I am responding to a post that is 11 months old, but am interested and hope that gets the count closer to six.
  10. esfoder
    esfoder
    from Oregon
    I don’t think anything ever came of it?
    Dusty
  11. mddan
    mddan
    from Newark, DE
    Wanted to let you know we have so far 5 orders so far this week into Clifford Performance and we need 9 orders to get the project off the ground. If you want to call Larry at Clifford Performance and put in an order you can help make this happen! Here is Clifford's number: Phone: 951-471-1161
  12. mddan
    mddan
    from Newark, DE
    We now have 7 orders for the 2x2 manifold, still need 2 more to make it happen!!!
  13. Tickety Boo
    Tickety Boo
    from Wisconsin
    A friend of mine has a 47 Hudson engine that was rebuilt at a local machine shop, now it has issues with the Babbitt
    rod bearings. The original Hudson manual spec.lists.0007 as the bearing clearance. That sounds too tight to me :eek:
    Could it be a miss print ? Two many 0s ?
    Engine is back out and apart ( looking for answers )
    Thanks Norb
  14. Studegator
    Studegator
    .001 to .0025, hard to find a shop that actually knows how to do Babbitt bearings. He needs to get a Hudson mechanical procedures manual. The HET club sells them very reasonable.
    Sent from my SM-T810 using Tapatalk
    Tickety Boo likes this.
  15. Tickety Boo
    Tickety Boo
    from Wisconsin
    Thank You
    Petes original Hudson (Red) manual shows .0007 must be a misprint. lol
    Norb
  16. Studegator
    Studegator
  17. Hud I
    Hud I
    from Tennessee
    You need to contact Randy Maas. He rebuilds the babbit engines. (309 267 6158). If you have any questions about these engines, he can answer it. LHud
  18. Studegator
    Studegator
    Where are you located? There is an excellent engine builder near Tampa (St. Pete) Fla that does Babbitt engine rebuilds. Some Hudson club members have used them.
    Godwin-Singer Inc.
    1415 Burlington Avenue North
    St.Petersburg, Fl 33705
    Phone 727-896-8631
    Fax 727-895-2463
    Another builder that I have heard good things about-
    http://www.babbitt-bearings.com/contact.aspx
    Another in Ohio-
    http://www.hartsmachineservice.com/home.html
    Another highly recommended -
    There is a company in Cazenovia NY called Reeve enterprises . They rebuild any engine and do all their own babbitt work. They rebuilt my Franklin engine.Nice people to deal with. 315 655 8812
    Interesting one in Wisconsin-
    http://www.fusionbabbitting.com/index.html
  19. Hnstray
    Hnstray
    from Quincy, IL
    The phone number Area Code Hud1 provided for Randy Maas is West Central Illinois..........
    Ray
  20. Tickety Boo
    Tickety Boo
    from Wisconsin
    This is the place to go to solve problems, Hammers always have the answers.
    Thanks Guys :cool:
    Pete told me today the machine shop already sent out the crank and rods for rebuild :eek:
    Now got to find out where ?
    Again ! Thanks for the Help :cool:
  21. 0nedon
    0nedon
    There is one on ebay (cars and trucks) with twin carbs.
  22. Hud I
    Hud I
    from Tennessee
    The Maas boys are in Manito,IL.
  23. esfoder
    esfoder
    from Oregon
    Did this go anywhere yet?
  24. Hud I
    Hud I
    from Tennessee
    I think it is getting ready to happen. You need to call Clifford Performance to get the latest update on the project.
  25. Hudson High
    Hudson High
    I have a 262 with a casting date of Sep 1950. How can I tell when a casting is a narrow or wide block?
  26. studebakerjoe
    studebakerjoe
    @Hudson High the first post in this thread explains it. If the panrail is straight from front engine plate to rear it's a narrow block.
    lostmind likes this.
  27. mddan
    mddan
    from Newark, DE
    The new Hudson head is shipping and the new 2x2 manifold is next. The intake CAD work is close to being done, we just need to optimize it for sand casting. Here is an earlier 3D printed version for those interested.
  28. Frames
    Frames
    308 bored .060. Edmunds head and intake. Vertex magnet img199.jpg img198.jpg img197.jpg img196.jpg o. Isky cam. Quartermaster 2 disc clutch, 37 Packard trans. 48 Ford front susp. 16-1 Corvette steering. Landrum 125 lbs leaf springs. My own custom built quckchange. 9" mini spool. F1oo axles. Aluminum grille shell. Aluminum radiator.
  29. patsurf
    patsurf
    we want to see LOTS more about that quickchange!!
  30. Frames
    Frames
    Using a a 35-48 Ford car banjo turned backwards and up side down. I made a fixture off a Halibrand 201 Trans sprint 032.jpg Trans sprint 033.jpg Trans sprint 034.jpg to install the front bearing retainer. Wood pattern to cast the extension. I built 5. Sold 2. Have 3 in my cars. Sold fixtures. He is in over his head. Never built any.
