I'm trying to identify this part to replace it since mine broke. I don't know if it's called a "perch," but that doesn't help me find the part in searches. It's the part that is attached to the axle with a bushing and is supposed to rest flat on the leaf springs (or in my case the lowering block). As you can see here, mine is broken. Sent from my iPhone using The H.A.M.B. mobile app
it's called a "spring seat" same one was used on cars for many years, and trucks also starting in 1948. should be easy to find a replacement, but it will probably be a used part, not new.
We call them spring pivots. And, I happen to have TWO of them we took off the 51 Bus Coupe. You can have them both for shipping costs. Just send a PM. I am Butch/56sedandelivery.
Yeah, the uneven stress from those U bolts may have caused the failure. Get some flatter U bolts that contact the spring seat fully
In looking further at your photos, it's easy to see why this happened. You should be using "squared" end U-bolts instead of the "rounded" style you have on there. It is stressing the metal, and causing it to crack/break. If the U-bolts are long enough, you could possibly weld in a "bridge" to make the ends square, but it would be best to obtain the correct style U-bolts. Offer still stands. I am Butch/56sedandelivery. DANG!!! I TYPED THIS EARLIER, AND NEVER ENTERED IT.^^^^^ALREADY ANSWERED^^^^^.
I'm glad a few beat me to it.. Get the right U bolts, and the right width blocks, 1.75" wide If I remember from when my car still had leafs. I might even have my old ones, I'll take a look.
I have seen those break even when no lowering blocks were used. There are a couple of different types, one is all centalised (like yours), the other has an offset pin and a long & short "ear" where the U bolts seat.
They sell the correct width blocks and u bolts for your 51 pretty cheap. Sent from my SM-J727T1 using The H.A.M.B. mobile app
