Event Coverage Welcome to the 2017 Meltdown Drags
Discussion in 'The Hokey Ass Message Board' started by Okiedoker, Oct 6, 2016.
  1. saltflats
    saltflats
    from Missouri
    You need to check all the connections from battery through the disconnect to starter.
    Maybe the disconnect is not any good.
    30dodgeboy, Gammz and loudbang like this.
  2. Gammz
    Gammz
    from Lincoln Ne
    Will do. Thinking about isolating it. Hook things up the way it was and see what's up.
  3. Gammz
    Gammz
    from Lincoln Ne
    I'm going to add a ground from the starter to the neg side of the battery too.
  4. wrenchbender
    wrenchbender
    Also make sure you have big enough batt cable and if you have relocated batt to back of car make sure you run a ground directly from the battery to the engine don't do the old use the chassis and two short cables it won't be good enough you will also need one from batt to body as well even better if you run one from engine to firewall as well good grounds are very important especially if you have msd ignition stuff
    loudbang, 30dodgeboy and Gammz like this.
  5. rocketsled59
    rocketsled59
    Check cables. They'll corrode way back inside insulation and look fine. Fords are the pickiest about good connections. Also if you painted your fresh engine/ bellhousing the paint where starter bolts on may not be allowing a good ground. Just food for thought. It's something stupid. Almost always is
    loudbang, Gammz and saltflats like this.
  6. Gammz
    Gammz
    from Lincoln Ne
    The something stupid is almost always me.....
    off work now to get some grounds ran. Battery to engine block.
  7. Gammz
    Gammz
    from Lincoln Ne
    Yeah. We relocated the battery. Used big ol 1-0 cable for power. Now I'm going to run a 1-0 ground from the battery to the engine block. I have a strap from the fire wall to the block now.
  8. Gammz
    Gammz
    from Lincoln Ne
    update. We ran a new ground cable from the battery to the engine block. Installed a new starter solenoid. New key switch. And drumroll.........
    Ignition!!! Now with all the new parts I'm not totally sure they were all the problem.
    We are pretty new at the build a car thing. Both have mechanical aptitude and love gear head shit. We did not run a ground from the battery to the block beforehand. It did have one when the battery was in the stock location. Lesson learned. This may have been the biggest mistake in the whole ordeal.
    Now to run a charge wire from the ALT back to the battery!
    Thanks to you guys with all the ideas! Hope to take it for some test n tune Friday night and some racing on Saturday.
  9. DubG
    DubG
    from Nebraska
    so i don't know if this is where to ask but since we are accepted for the h.a.m.b. drags in august, i've realized we need to decide on a class to register in. I know we're not stock anymore, so do we register in gas coupe/sedan or competition coupe/sedan? i figured most of you know what we've got going on now.
  10. Deuced Up!
    Deuced Up!
    loudbang, DubG and Gammz like this.
  11. rawcjw19
    rawcjw19
    Gammz didn't feel to bad. My car wouldn't start last year. I ran and bought a new battery and all it ended up being was paint behind my alternater kept it from charging
  12. saltflats
    saltflats
    from Missouri
    We have started life support......
    BigDrag, squirrel, Deuced Up! and 7 others like this.
  13. BigDrag
    BigDrag
    from Milwaukee
    Some shots from the 20th Reunion for those who couldn't make it to Great Lakes Dragaway.
    DSC_0011.JPG DSC_0902.JPG DSC_0997.JPG DSC_0079.JPG DSC_0025.JPG DSC_0014.JPG DSC_0045.JPG DSC_0049.JPG DSC_0910.JPG DSC_0901.JPG DSC_0022.JPG
  14. BigDrag
    BigDrag
    from Milwaukee
  15. saltflats
    saltflats
    from Missouri
    Great pictures BIGDRAG!!!!!
    I like the time slip shots and the big smiles.
    BigDrag, stupesnova, loudbang and 3 others like this.
  16. enloe
    enloe
    from east , tn.
  17. They also help increase the signal to the boosters, as some is lost with the bigger plenum area of a tunnel ram. I was gonna wait to see how fast your new combo is, before I talked you into a pair of shear plates Norb. Scott, probably better try those on Sunday, I'm not sure it's a good idea to show up at the Meltdown, with anything named "shear" on your car.., DAMN BAD VOICES!
  18. Or... you could do what I did and run a belt-driven signal booster!
    :D:D:D
    powrshftr, loudbang and racer-x like this.
  19. "Lake Shaft Shreader" doing it best impression of the Pokey Choker
    55belairx2 and loudbang like this.
  20. Well, I know this guy that did that to the small block in his '57 Chevy, but it still only runs 11's:(
  21. Shifty Shim Skat'n Shaker
  22. You better lock that thing up at night, my brother Marc & I are Anglia hounds!
    Scott Mize, 55belairx2 and loudbang like this.
  23. I have two, you want a gold one, or a plain satin aluminum one. I'll trade ya a beer for it at the Meltdown.
    55belairx2, DubG, Tickety Boo and 3 others like this.
  24. owwwww, that had to hurt!!
    :D
  25. powrshftr
    powrshftr
    Got the last of the stuff for tie-downs and ratchet straps for the new trailer this morning.
    Picking up 15gal of C12 this afternoon.
    Should be making some test passes with the car this weekend if we're extremely lucky.
  26. Gammz
    Gammz
    from Lincoln Ne
    I'm going to try again tonight......
    loudbang, powrshftr and Tickety Boo like this.
  27. saltflats
    saltflats
    from Missouri
    If I don't run out of steam......hope to have power train back in tonight.
  28. BLACK STUDE
    BLACK STUDE
    Dynoed the new 464 for the Hemi Hunter yesterday. 703 HP at 6400, 626 torque at 5100. My poor stude is not gonna know what hit it. Gotta get busy and load this bullet in the chamber. Gonna be interesting with the altered wheelbase. IMG_20170608_153412856.jpg
  29. Gammz
    Gammz
    from Lincoln Ne
    Mans game
    loudbang, 55belairx2 and powrshftr like this.
  30. Okiedoker
    Okiedoker
    from Wisconsin
    PRO TIP: you may want to double check that you have your u-bolts and drive shaft straps tightened to the manufacturers specifications or catastrophic failure may occur....again!
