Features Let's see the dash ~ work in progress or finished.
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Apr 22, 2017.
  1. Fitnessguy
    Fitnessguy
    Here's mine unfinished. Need to find the right home for the tach still as well. IMG_1744.JPG IMG_2287.JPG IMG_2288.JPG IMG_2128.JPG
  2. seb fontana
    seb fontana
    from ct
    Not written in stone; my memory says those sending units only worked on on odd number tachs, 5k, 7k, 9k...[​IMG]
  3. seb fontana
    seb fontana
    from ct
    Shoebox in a Shoebox...Few addisions in 45 years but basically the same.. 51 New Pics 005.jpg
    esrbuilders and Bandit Billy like this.
  4. IMG_1594.JPG IMG_1595.JPG IMG_0216.JPG IMG_1596.JPG This is the dash in the '35 Chevy. It's actually a '34 Master dash panel, but it bolts right into the '35 Standard, andit moves the gauges from the center to the left side, and adds a glove box on the right. Covered up the billet aluminum insert with a piece of guitar pick guard material routed to the proper shape.
  5. Fatbrosracing
    Fatbrosracing
    from Australia
  6. koolkemp
    koolkemp
    Here's the wasted 49 Mercury dash I fixed and narrowed for my 47 Ford .[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Cheeta, mgtstumpy, slimcat7m3 and 5 others like this.
  7. chop job
    chop job
    from Wisconsin
    1. WISCONSON HAMBERS
  8. FORDY 6
    FORDY 6
    The dash panel in my '29 Roadster project, I added the lights and gauges 20170414_132713.jpg . Not sure what it is...boat, car? maybe someone knows.
  9. Some very beautiful dashes in there and some that a heap of thought and work has been taken to make them work. Can I suggest though that the idea of the instrument panel was first and foremost is the inform the driver of what his or her engine is doing in regards of the two critical ones, oil pressure and engine temperature. With that said, one must be able to not only see the gauges, but be able to read them at a glance so when working on ones dash, remember it has to not only look good but be functional too so that is where the individual owner builder has to decide. I like the high polished look on some of the surrounds but would that effect allow sunlight to reflect back into the drivers eyes ? Those are the sort of questions only the owner can answer but then really should be taken into consideration before it is so called " Finished " . I have a basic panel in my T Roadster with the switches and ignition down on the seat base as I like to drive with my seat belt on yet still be able to reach the switches easily. 009.jpg
    Max Gearhead likes this.
  10. Tried to do something a little different from the normal flat dash on my T. I stamped a dash and rolled the lower edge to look similar to an A tank, fitted it with a '29 cluster filled with SW gauges, and topped along a hammer formed "dash rail".
    slimcat7m3, deadbeat, 54reno and 5 others like this.
  11. Rogga
    Rogga
    Chevy 1955. Nothing fancy other than filled radio and lighter holes. Whole dash is silver metallic. 20170405_192149.jpg
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ Here's a portion of mine. Radio hole is still there it's just covered by optional no hole trim. [​IMG]
    Rogga likes this.
  13. rc57
    rc57
    Since we're in the '55 zone, here's mine in my '57 truck
    Cheeta, rod1, mgtstumpy and 3 others like this.
  14. Narrowed '54 Vauxhall dash in my '22 roadster pickup/bucket.[​IMG]
    Bear
    Sent from my SM-G930F using The H.A.M.B. mobile app
  15. Here are a couple. A '35/6 dash going in the '32 sedan build with some slightly different gauges. And then the dash done quite a few years ago in the '36 roadster............hardly anyone knew what it was from. 32 in shop 18.JPG 32 in shop 19.JPG 36dash4.jpg 005a.jpg
    mgtstumpy and rc57 like this.
  16. jakesbackyard
    jakesbackyard
    from ND
    1. Upholstery
    '40 dash in my Model A...
  17. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Scribed steering tube vs unscribed.[​IMG] [​IMG]
    Dave Mc likes this.
  18. firemangordy
    firemangordy
  19. coilover
    coilover
    from Texas
    39 Ford Standard with under dash a/c unit mounted up in dash. This gives instant heat/cool since it has no ducting and all controls are built in. Have used on several cars with good results.
    Hnstray and deadbeat like this.
  20. chessterd5
    chessterd5
    from u.s.a.
    Nothing fancy, it's a 1941 GMC truck dash cut down to fit a 1927 Model T coupe.
  21. big duece
    big duece
    from kansas
    3w dash that was in horrible shape when I received it. Thank god for POR 15 DSC09901.JPG DSC09902.JPG
    mgtstumpy, deadbeat and FORDY 6 like this.
  22. CA. 280
    CA. 280
    1st personalizing attempt on my first car. 33 5 window. Vinyl wrapped, date says it all. Scan.jpg
    Just realized no matter how things change they always stay the same. Was driving a 35 year old car then and drive a 42 year old car now.
  23. Fat47
    Fat47
  24. 50Fraud
    50Fraud
    I'm not sure if this one is finished or not:
  25. Pat Pryor
    Pat Pryor
    I just redid my dash,
    Before
    After
    mgtstumpy and Speed~On like this.
  26. seb fontana
    seb fontana
    from ct
  27. Joliet Jake
    Joliet Jake
    from Jax, FL
    My WIP 31 Ford coupe with a 51 Ford dash.
  28. 50Fraud
    50Fraud
    Dash in my '40: mostly stock, but cleaned up considerably:
    Cheeta, 30tudor, mgtstumpy and 5 others like this.
  29. LOWDUG37
    LOWDUG37
    IMG_0587.JPG my 36 3-window
    mgtstumpy likes this.
  30. Chavezk21
    Chavezk21
