Technical 327 : Large vs Small Journal
Discussion in 'The Hokey Ass Message Board' started by Wyld Deuce, Feb 18, 2017.
  1. Wyld Deuce
    Wyld Deuce
    from ...
    Aside from the obvious......
    What is the difference between the large and small journal engines?
    Is one better than the other? (performance, parts, size .....)
    1Nimrod, Deuces and henryj1951 like this.
  2. henryj1951
    henryj1951
    from USA
    .....got busy had to answer the call BRB
    friction ,
    reciprocating weight ,
    lot of variances to rpms and intended use
    dang phone brb
    Darryl Deir likes this.
  3. Kan Kustom
    Kan Kustom
    Calling Squirrel........ He knows these things.
  4. From what little I have heard the small journal is supposedly the strongest & the heaviest,but I am no expert - The guys I thank are as knowledgeable as any is Squirrel & Beano. HRP
  5. henryj1951
    henryj1951
    from USA
    HRP is correct on the stronger crank , small journal also decreases the surface speed of the bearing and it a has a reduced negative torque that the large bearing does.
    might be worth 3-5 hp, but you will never see that on a dyno.
    If i was in the room with Jim and beano out of the 3 of us BOTH of them would still BE smarter than me.
    Deuces and Montana1 like this.
  6. finn
    finn
    It's been a long time, but I recall that the early small journal 327s had a forged crankshaft, while the large journal cranks were cast.
    Overall crank strength may be similar though, given that larger journals generally mean more pin overlap.
    1Nimrod and henryj1951 like this.
  7. falcongeorge
    falcongeorge
    from BC
    I'm not so sure about that...
    henryj1951 likes this.
  8. slowmotion
    slowmotion
    I seem to recall certain M/P guys sought the small journal cranks for twisting those screamers into the twilight zone (& beyond). :eek:
    olscrounger, Deuces, loudbang and 2 others like this.
  9. What do you plan to do with this 327, if I might ask...Makes all the difference in the world. LOL
    1Nimrod, loudbang and henryj1951 like this.
  10. You know a lot more than your letting on~
    Am I right in thinking that tall the small journal 283 & 327's cranks were forged steel cranks? HRP
    olscrounger likes this.
  11. No
  12. joel
    joel
    There are large journal forged cranks (GM ), but Eagle is much more plentiful. It's tough to find as good small journal rods as large journal for the money. In the '60's I knew a couple of guys that had water leaks at +.060". AS stated above I think the main thing is bearing speed.
    Fordors likes this.
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    What do you want to do with it ? If you wanna say I have a 327 it don't matter. If you wanna swing it high in rpm's a small journal then.
    Darryl Deir and olscrounger like this.
  14. toxic waste
    toxic waste
    from Iowa
    How much hores power are you wanting? It really don't make much difference.
  15. 56sedandelivery
    56sedandelivery
    Most 283 and small journal 327 cranks were forged; the later 283's got cast cranks however. The large journal 327 used both cast and forged cranks; I have both in the garage. Holler if you need one. Guys used to use the large journal, forged, 327 crank, but have the rod journals turned to small journal size, thereby slinging lighter connecting rods, less rod bearing surface/speed, and a stronger bottom end was the purpose. But, in a street car, it makes NO difference at all. I am Butch/56sedandelivery.
    1Nimrod, dana barlow, indyjps and 3 others like this.
  16. Montana1
    Montana1
    Bearing surface speed is lower on the small journal making less friction for higher rpm's.
    That helps the 327 wind up to the sky if you can get the air to them! ;)
    Higher rpm's translates to more HP per cu. in.
    Plus the 327 has an ideal rod to stroke ratio (1.75) for lower piston side thrust, meaning less friction. That's why everybody likes them.
    That ought to stir the pot. :eek::D
    1Nimrod and Deuces like this.
  17. 283 cranks fit into small journal crank 327.
  18. 32v
    32v
    from v.i.
    hmm, I have a nos gm 302 nitrated crank for sale if interested
    1Nimrod, Deuces and kidcampbell71 like this.
  19. Most of the small journal cranks did not have a drilled snout for a bolt to hold the harmonic balancer on. And a 283 crank will fit in a small journal block. the large journal block is practically the as a 350 block. Boring a small journal block past .030 is kinda iffy. I have several of both kinds of 327,s in my hoard. they aint for sale.
  20. DDDenny
    I have an NOS oem nitrided small journal crank in my Nova 327 plus .040 as well as NOS rods.
    No they are not for sale.
    1Nimrod likes this.
  21. Wyld Deuce
    Wyld Deuce
    from ...
    One day I would like to get one and rebuild it.....Stick into a hot rod that I do not currently possess.
    Daily driver mostly, not to mention the drag strip is only 6 miles away.
    I have a heavy foot and like to play. :D
    I've always known about the two models, just not the differences.
    I wasn't sure if it was anything like the 351c/351w scenario.
    1Nimrod, Deuces and loudbang like this.
  22. In that case, just build a more modern 383 and tell everyone it's a large journal 327.
  23. henryj1951
    henryj1951
    from USA
    ah yep.... 383
  24. southcross2631
    southcross2631
    Raced both in Modified production . Put studs in the mains ,ran aluminum rods turned them both over 8 grand. GM cranks turned polished and balanced.
    1Nimrod, Deuces and Montana1 like this.
  25. willowbilly3
    willowbilly3
    from Sturgis
    I always preferred the small journal. I have been told they all have steel cranks. Less bearing speed. Guy who used to build our roundy round dirt car engines only built small journal for that reason. The only negative, small as it might be, is that you can used a 4 bolt main cap block to build a large journal but that just a lot of smoke and mirrors people have been sold IMO. Never seen a well built small journal for a street car have lower end issues.
  26. You won't see a difference in performance between a big or small journal 327. The big journals came out in 1968 because Chevy had transitioned to big journal when the 350 came out. Most small journal 327 cranks were steel, some were cast. I have found the opposite to be true with the big journal stuff. Big journal 327 cranks are hard to find, especially steel, because by mid 1969, the 327 production was stopped, and it's applications were split between the 307 on the economy end and the 350 on the mid and high performance end. The 327 is one of my favorite small blocks because it does everything right. It's got decent torque, great midrange, and will rev to the moon. And on the big block side, the 427 is the same kind of animal, only meaner. It was like the stars were in perfect alignment when the 327 and the 427 were conceived. GREAT ENGINES.
    Sent from my QMV7A using The H.A.M.B. mobile app
  27. Onemansjunk
    Onemansjunk
    from Modesto,CA
    Butch/56sedandelivery is correct about turning the rod journals down on the forged large journal 327 cranks! Some would machine them off-center---"ECCENTRIC "--to increase the "THROW"--and-"STROKE ".Re-balancing was the KEY!
  28. sunbeam
    sunbeam
    Put a 327 crank in 400 block get the short stroke and 350 inches
    Peter Nowak and Deuces like this.
  29. fatassbuick
    fatassbuick
    from Kentucky
    Put a 283 crank into a 327 and you've got a 301 (basically, a 302 Z28 motor). Small journal is apparently easier to get the good stuff. The ratio between bore and stroke of this hybrid is considered perfectly square (old fart language) for torque vs RPMs, bleh bleh. Small has more balls.
    This is great thread, love this board for details.
  30. henryj1951
    henryj1951
    from USA
    bore (4.00)x bore (4.00) x .7854 x cylinders (8) x crank stroke 3.00 =
    you do the math
    the old 283 turned into a ---___________<---
