Hello, I do congratulate you for the project. It 'a very ambitious project even here in America. In Italy / Europe I think is the best there is when it will be finished. Sincere congratulations to those who have thought and designed this magnificent Kustom. If you can, I ask you to document the next steps, in great detail. When you start with the work exactly? Who is running to you the work of this project in Italy? Good job.
have you found someone to finish your car outside Italy? Or have you found someone from you in Rome? Let's wait a few more days as you wrote now. Regards
we can say that the circle is closed. Car back into the hands of those who had begun at the time, in Lecco. Roman brackets has been crucial to set up lines as I wanted. Now we go to the end.
Ok, Good work !!! .... If you maintain the premises that you described in the previous post, without changing ... this will be an excellent Kustom. hopefully we can see it's over soon!
beautiful line of this self Mirko. It seems to be stretched a little longer rear fender. If you stretch a little bit more towards the back, you can go down with the tail and make everything more harmonious to see.
Technical tests, changes and more. Door will be stretched in fender and extended down....... Inviato dal mio iPhone utilizzando Tapatalk
That panel with the Caddy emblem is just "Too Kool for Skool!" And placing it where it shows only when the door is open is understated elegance.
