Technical Spindle removal, 48 chevy orig suspension
Discussion in 'Traditional Hot Rods' started by mack57, Jan 29, 2017.
  1. mack57
    mack57
  2. rtp
    rtp
    see the threaded cross shaft that the spindle clamps to , it has a hex in the end you put a hex wrench in and turn it out. The threaded shaft is an off center part it is used to set caster and camber. It should come out easy.
  3. rtp
    rtp
    Make sure to have the weight of the car on the lower a arm ,or you will have a hard time turning it. ALSO the spring may jump out and hurt you.
  4. mack57
    mack57
  5. mack57
    mack57
  6. mack57
    mack57
  7. rtp
    rtp
    Got a picture ? Been a while.
  8. mack57
    mack57
  9. mack57
    mack57
  10. rtp
    rtp
  11. mack57
    mack57
    Ok, can't seem to budge it either way. Tried heat too. I'll keep after it.
  12. rtp
    rtp
    I will see if the shop manul has any thing on that .may take a day to find it.
    Sent from my VS987 using The H.A.M.B. mobile app
  13. mack57
    mack57
  14. I have done it a couple of years ago, can't remember any LH threads on there though. That cut looks nasty, couldnt budge the king pin? I know i used a lot of heat , a lot of cussin, and a BFH!
    mack57 likes this.
  15. mack57
    mack57
    Hahaha! I'm sure about the cussin & BFH!
    I'm trying to remove the spindle bushing at the bottom of the pic.
  16. Mr48chev
    You can look at the new bushings and figure out if the threads are left or right hand.
  17. mack57
    mack57
    I don't have new bushings, although maybe should look into new....
