Technical Lighted Welding Helmet, cheapo !
Discussion in 'Traditional Hot Rods' started by sloppy jalopies, Dec 6, 2016.
  1. Blue One
    Blue One
    from Alberta
    Exactly ! As I recommended in post 16. This is the way to go.
  2. TigerFan
    TigerFan
    from Athens, GA
    What a simple solution to a common problem. Just the other night I was welding under bright light, but on a corner of the project that was in a shadow, wishing I could fix it. Here's my solution!
  3. Alger
    Alger
    from Sacto
    What a great idea, I have a headlamp around here somewhere I can try out, thanks for sharing!
  4. FOURTYDLX
    FOURTYDLX
    Hot glue a piece of tin to helmet, then Harbor Freight mag light will stick to it. Lot's of great ideas here.
  5. statesblue
    statesblue
    from Luzerne Pa
    You get a big piece of raisin pie for that idea...I cant wait to try it.
  6. jnaki
    jnaki
    Hello SJ,
    What a great idea. Back in the high school metal shop class, most people learned gas welding and those goggles at least had less darkness than the arc welding flip lids. If we had these lights back then, we probably would have stayed in those welding classes. It would have made the beads a lot better and smoother. That was one thing I did not like was the visibility of the object being welded when the flip lids came down. The arc welding beads just did not come out like they should. In gas welding, these lights or some other lights could have also been used (there weren't any or no one was inventive enough to experiment), but our beads/welds were pretty good. I give “Kudos” to those who make smooth uniform beads from the modern day welders. It still is a technique to be mastered.
    Jnaki
  7. BamaMav
    BamaMav
    from Berry, AL
    Great Idea! Gonna steal this one! Now I just need to get another auto darkening helmet, my last one petered out and won't lighten up anymore. New battery didn't help, must have dropped it on the concrete floor one time too many.
  8. 1927Tudor
    1927Tudor
    Brilliant. Also stealing this one.
  9. gdaddy
    gdaddy
    from nw fl.
    very good , going to try it , thanks for sharing
  10. patmanta
    patmanta
    from Woburn, MA
    1. MASSACHUSETTS HAMB
    YOU ARE WRONG; THAT IDEA IS AMAZING.
  11. sloppy jalopies
    sloppy jalopies
    when you see them for sale at your welding supply store you can tell your buddies that you saw it first...
    ....... so cheap and easy..... think i dated her sister !
  12. Drewski
    Drewski
    I use this rig when I'm welding under a vehicle in tight dark areas. Cheap harbor freight led (free) couple hose clamps and short piece of metal.
  13. FOURTYDLX
    FOURTYDLX
    I stoled it to.
  14. L. Eckart
    L. Eckart
    Going to rig up something similar. THANKS for the idea!
  15. Damn..another of those why didn't I think of that ideas.
    Thanks
    '51 Norm and DenK like this.
  16. sloppy jalopies
    sloppy jalopies
    lost in the crowd... but may still help...
  17. I don't know.. what will I blame my birdshit bubblegum welds on now?
    '51 Norm and Jet96 like this.
  18. Atwater Mike
    Atwater Mike
    ...that was my other concern!
  19. neilswheels
    neilswheels
    from England
    On the 'glasses' side,I've got a Lincoln helmet that takes their lenses that match your glasses' Helmet wasn't the cheapest (one of the 'Chip Foose' editions), but the lenses are cheap, and if your eyes get worse, you can slide out the old lense and slide in a new one. Improved my TIGing no end.
    tubman likes this.
  20. sloppy jalopies
    sloppy jalopies
    used it again inside the car... i can't weld without the darn thing ...
  21. Hot Rod 50
    Hot Rod 50
    I got one of those headband led lights and put it around my helmet. Works pretty good.
  22. sloppy jalopies
    sloppy jalopies
    been a few months, thought it might be a good time to refresh...
    cheap helmet update... right before Christmas and all...
  23. seb fontana
    seb fontana
    from ct
    ^^X2---Reminds me I got to go to the welding supply shop and buy me something for x mas..Dog likes to visit too..I put one of the HF forehead light on my helmet when I read the first post..Real quick and dirty screwed a 90° piece of sheet metal to hood above the lens, stuck the light on and adjusted sheet metal angle to suit focal point of weld..Shazam!!
  24. Mr48chev
    I missed this thread the first time around but am for sure going to put one on my helmet.
    I have worn bifocals for 30 years and am going to get a pair of glasses with just the close vision lens aka reading glasses to use too. That should help with the tilt the head to see better thing.
  25. indyjps
    indyjps
    Hmm, I use a clip on light that goes on a hat bill when Im under the car. Bet I could clip it to the edge of my helmet.
    tommyd likes this.
  26. LWEL9226
    LWEL9226
    from So. Oregon
    When I was still working I used single-vision prescription safety glasses for welding, now that I
    have retired I use "drugstore" reading glasses in the right power to suit me.... works very well........
    LynnW
  27. fullhouse296
    fullhouse296
    from Australia
    They make a auto darkening helmet now ! even comes with replaceable magnafying covers . wot next ?
  28. southcross2631
    southcross2631
    I have had a freebie harbor freight light velcroed to my welding helmet for 2 years now.
    That way if I want to remove it no problem. Makes floor pan or roll cage welding much easier.
  29. wonder if you could attach a metal mirror to the helmet so when you start welding the light from welding reflects back onto the work to help you see better? Might save some batteries. :)
  30. sloppy jalopies
    sloppy jalopies
    when the manufacturers start building them in, the batts will charge with the weld like the lenses do...
    rpm56 likes this.
