Technical spi epoxy primer
Discussion in 'The Hokey Ass Message Board' started by brakepad, Oct 13, 2016.
  1. brakepad
    brakepad
    hi new member trying to find members that have used spi epoxy primer . like to know what they think about it vs other epoxy primers like ppg dplf or cromax going to prime 55 chevy after dustless blasting . trying to do it right and do not want any problems later.
  2. I have not used it, but will use it. Always heard great things about their products and while at the LA roadster show last June, I had a chance to talk with their rep. Answered all questions about the primer. They gave me a detailed instruction booklet about the product, prep and application.
    Texas Webb likes this.
  3. brakepad
    brakepad
    all I hear are good things too. thanks for your reply
  4. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    GREAT Epoxy. You can't get any better support and customer service on Earth than what
    Barry provides. All of their products are TOP shelf for 40% less than the Big Guys.
    Happy spraying,
    VR&C.
    loudbang and Texas Webb like this.
  5. chargin03
    chargin03
    Great stuff and you can not get any better than Barry he will answer all your questions even if your not using his product.
  6. jaw22w
    jaw22w
    from Indiana
    I tried the black SPI epoxy on my sand blasted 26T. It has been on there 2+ years now. It has stood up great. Goes on easy. One real good point is that it sands much easier than the dp90lf I used to use. I epoxy'ed it right after sand blasting. The spi epoxy has kind of a sheen to it. You can use it as kind of a guide coat because the low spots will have that sheen to it, assuming you're using a board. After body work, I gave it another over all coat. IIRC I had about $120 in .5 gallon total of DP. I had $175 in 2 gallons total of SPI. I highly recommend SPI over the DP stuff. Price and performance.
  7. I've been using it about 11-12 years. Great products.
  8. brakepad
    brakepad
  9. brakepad
    brakepad
  10. brakepad
    brakepad
  11. hotrod428
    hotrod428
    who sells the SPI primer?
  12. chargin03
    chargin03
    SPI 404-307-9740 Tech 706-781-2220 Barry. free delivery.
  13. 35WINDOW
    35WINDOW
    X100-I love the stuff, and have been using it for over 10 Years-the good part is that abuot 2-3 Years ago they made it UV resistant-I love their Black Single Stage too-
  14. 28TUDOR
    28TUDOR
    Used it last night! It works great. I use his clears also.
  15. brakepad
    brakepad
  16. brakepad
    brakepad
  17. Binger
    Binger
    from wyoming
    Never used that one. I like the Nason line. Used that on my coupe and it turned out well. There is a great thread called 'the difference in primers' (I think). There is lots of great information about all primers in that one.
  18. Here's the link to the article Binger mentioned.
    More required reading... for me anyway.
  19. nochop
    nochop
    from norcal
    How did the dustless blast work out? How much was cost?
  20. Shamedevil
    Shamedevil
  21. brakepad
    brakepad
    thanks for the info
  22. brakepad
    brakepad
    thanks for getting back to me
  23. brakepad
    brakepad
    thanks for link it has a lot of good info
  24. brakepad
    brakepad
    did not blast yet around the 20th of the month
  25. nochop
    nochop
    from norcal
    Cool, keep me posted on the blast and primer job if you could. I going to pull the the same thing soon on my coupe
  26. Binger
    Binger
    from wyoming
    Thanks for posting that link. I don't know how to post a link off of my phone and was not near a computer.
