Art & Inspiration This one threw me ('til I got closer)
Discussion in 'The Hokey Ass Message Board' started by choffman41, Oct 5, 2016.
    kidcampbell71 likes this.
  2. Fortunateson
    Fortunateson
    May have a GMC engine but that is an Internationaal.
    LOU WELLS likes this.
  3. oldrelics
    oldrelics
    from Calgary
    Looks like an international to me
  4. deucendude
    deucendude
    from norcal
    International to me too.
  5. ,,,aah,,,did you forget your medicine?
  6. Deuced Up!
    Deuced Up!
    Google Images thinks it is an International as well.... :p
  7. BJR
    BJR
    46 to 49 International with the stainless grill bars.
  8. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    Grew up on a farm, sure looks International to me?
  9. harley rider
    harley rider
    I guess you didn't get close enough.
  10. Hint: go and make that optometrist appointment now :D
    wojojo likes this.
  11. Speed Gems
    Speed Gems
    What's the smallest line you can read?
  12. O.K. I'll admit to being an idiot. The thing that got me was the fact that the whole grille was welded to the fenders. I can see now that they probably torched it out to remove the engine, then welded it back in. They did a pretty good job though. There's no idiot like a blind idiot.
  13. F&J
    F&J
    Can I give you advice: Please do not EVER offer to help a buddy of yours that buys a KB, and wants you to remove the front fenders or anything near that dam grille....he,he.
    I have never ever seen such a nightmare of the way the grille trim is long strips tying everything together, and tiny rusted nuts...DOZENs of them, all rusted up and inner trim clips just spinning, and not able to get it apart..
    I'd bet the guy did one before....and said "no way I'm going through that again"...and cut it.
  14. F&J
    F&J
    I've had a horrible flashback on when I got stuck with working on a guys 48 KB job. The REAL reason is that it's even tougher than just rusted nuts! I figured out that you cannot even get to some of the nuts at all! The factory assembled the fenders/header and grille trim off the truck and THEN slid the nose on!
    This guy comes to mind, to properly describe how smart IH was:
    And...after you get the grill back together, and try to get the column shifted Selector-Type trans into first or 2nd...the shift just won't go. So you go look how it works: One main lever on column bottom to move all 4 gear positions, but a stupid cable idea, running from slopped -out column, over to the top of the former older trans tower, and the IH "farmer design team" just sawed the old shift lever off, and uses the cable to move the gate right to left.. good grief....
    clunker likes this.
  15. Deuced Up!
    Deuced Up!
    Speed Gems...I think line 4 and 5 of your chart are problem. :p
    Duellym, Speed Gems and deucemac like this.
  16. The complete stainless bar set for that grill is usually worth more than the whole truck.
