Technical odd screws
Discussion in 'The Hokey Ass Message Board' started by robtlor, Jul 23, 2016.
  1. robtlor
    robtlor
    from Lincoln NE
    I am in need of an odd screwdriver, the screws have a rectangle male side on the top of screw so driver needs to have female side. These screws are on the vacuum wiper in a 55 chevy. Anyone seen these? Know where I can get one? Thanks, Bob
  2. squirrel
    needle nose pliers work. Or get an old philips screwdriver, grind off the point, and cut a slot in it.
    wraymen and LOU WELLS like this.
  3. 302GMC
    302GMC
    from Idaho
    I made a socket to fit them. Use one of those tiny 1/4" drive 12 point sockets that don't fit anything, heat it, & squeeze it in the vise til it fits.
    F&J and squirrel like this.
  4. 55Brodie
    55Brodie
    The tool you need is called a clutch-head screw driver.
    Speed Gems likes this.
  5. No...not a clutch head....
  6. squirrel
    it's almost an inverse clutch head. But straight, not curved along the sides.
    pic stolen from the internets...
  7. gatz
    gatz
    ^^ to take that one step further; which will help keep the tangs from spreading out...
    ( assuming the distance across the screw head is not larger than the tubing or shaft OD )
    After the notch is made, turn or find a short piece of tubing that fits closely over the area to reinforce it.
    Can be Loc-Tited or soldered on.
    Hnstray likes this.
  8. Clutch head is female, right??
  9. squirrel
    yes, clutch head is female.
  10. 55Brodie
    55Brodie
    I stand corrected. I always thought those were pliers head screws....never knew there was a tool for them!
  11. Squirrel so smart! Why didn't I think of that. I used small vice grips. Guess that's why squirrel gets the big bucks!
  12. olscrounger
    olscrounger
    I did what 302 GMC said--works fine
  13. Hotrodmyk
    Hotrodmyk
    1. Northwest HAMBers
    I have used small ignition wrenches on these.
  14. OahuEli
    OahuEli
    from Hawaii
    Hm. Saw the topic wording and "Crazy Michelle" came to mind...:rolleyes::D
    Hnstray and Saxman like this.
  15. 56premiere
    56premiere
    I squeeze a piece of brake tube ,. or copper tube. Put a bend in for torque.
