Projects 1957 DESOTO Firesweep
Discussion in 'The Hokey Ass Message Board' started by baker53, Jan 28, 2014.
  1. tattoos by brandon
    tattoos by brandon
    from salem ohio
    Thank you so much and very very nice cars
  2. baker53
    baker53
    Decided to change the front drum brakes to disc. Found a vendor in FL that sells caliper mounting plates that will allow the use of the original 14" wheels. Every other vendor I contacted indicated that I would have to go to 15 inch wheels which was just not an option for me. The caliper mounting plates and inner bearing bushings cost around $225 and the rest of the parts ran about $250 from Rock Auto. I did have to do a little mill work on the steering arms so that they would clear the lower ball joints. I also changed the single master cylinder to a dual unit and added an adjustable proportioning valve for the rear brakes for $75. My car is fitted with power brakes and the booster mounts above the master cylinder and the new dual master cylinder would not fit with the standard cap. I machined a new cap out of 1/2" aluminum and installed a couple of right angle fittings that go to the remote reservoir that I mounted on the firewall.
    DB1.jpg DB5.jpg DB6.jpg DB1.jpg DB5.jpg DB6.jpg DB8.jpg mc1.jpg mc2.jpg mc-2.jpg mc3.jpg mc4.jpg mc9.jpg
      716.8 KB
      716.3 KB
      760.7 KB
      665.8 KB
      665.8 KB
    Arominus and Gotgas like this.
