An HA/GR (& other classes) Place for Discussion
Discussion in 'HA/GR' started by 64 DODGE 440, Dec 1, 2014.
  1. bobw
    bobw
    Since there aren't any SDRA style cars in my area I might build a frame like this Chassis Research copy and put my driveline in it. Not before next fall though.
  2.
  3. Bobw, I would like to see that!
  4. Old6rodder
    Old6rodder
    from SoCal
    1. HA/GR owners group
    Here's what Dimitri did for their Fenn style cage in response to NHRA's whining. Haven't had any rejections over it yet.
    Daniel Clark likes this.
  5. old sparks
    old sparks
    I`m in the same boat as bobw. No one to class race within 400 miles, my own fault. I also have been thinking about a slingshot. Good way to go quicker with my existing powertrain. Love the K88 style but don`t want to fight tech every time I go to the track. Slingshots have been around since 1955 so I don`t think I would be considered a traitor. Besides, who`s gonna bitch.
  6. bobw
    bobw
    Thanks Dick, I've been collecting pics of Fenn-Style chassis that have roll cage modifications in order to pass tech. My main concern is with the laid back seat I might no be able to get out of the thing.
    I bought a 180 degree die for my (borrowed) tubing bender so I can make that signature "Fenn Bend".
  7. Daniel Clark
    Daniel Clark
    I like the rabbit ear car idea bobw!!!!
    old6rodder, did he get the chassis certified wth the modifications? How much grief did tech give him after the modifications?
  8. bobw
    bobw
    Daniel, it's flathead powered so I don't think he is going quicker than 10.00. Slower than 10.00 does not need to be certified. It's up to the tech inspector to "like" the roll cage configuration. Anything that doesn't look like the rule book diagrams is suspect. So a car could get okay'ed at one drag strip and not at another.
    Here's another attempt at "making it legal". He has a vertical down tube on the front hoop. Probably should have one on the second hoop too. And helmet bars. With all that you tend to lose the original style. But at least the chances of getting killed in it are reduced. My car should run in the high-mid 11 second range and that should influence the inspectors to go easy.
  9. old sparks
    old sparks
    Getting a car certed , even sportsman , can be a pain in the butt. Sportsman is every 2 years and pro is every year.Even then you are at the mercy of the inspector which no one wants to hear my opinion of. My take is the combos we use are not going to put us in the 9`s so we are only at the mercy of track tech. which can be bad enough. If you build a car that impresses the inspector and you have all the safety gear current , there won`t be a problem. My home track tech doesn`t even look at the car except the belt date. Either that or it`s so ugly it`s unforgettable. Word at he track is you don`t need a physical to get a 7.50 ticket but you still need the chassis cert. Won`t be long before you need all that to run 12`s . New rules always coming out get ready to spend
  10. Got a question for you guys,
    I've been looking at pics of some of the different builds and have noticed it looks like some are running vent lines on their fuel tanks and some not.So who is and who doesen't ? Does it make a difference?
  11. old sparks
    old sparks
    Rules state that you must have a vent installed in such a manner that prevents fuel spill in the event of a roll over. That can be a check valve or in my case a tube entering the top of the tank run to the bottom of the tank making a 90 back up about 1 inch from the top letting the tank vent but not letting it drain in case of a rollover. The commercial check valves are expensive
  12. Old6rodder
    Old6rodder
    from SoCal
    Ours is a simple double loop off the top of the tank. the concept being that you'd have to roll/flip several times to allow any out the tube end, and even then it'd be minuscule.
    Eight years, and haven't had a tech down check it yet.
  13. Old28
    Old28
    Last time I checked to get a Chassis Cert all the owner needed was to be a NHRA member and a hand full of cash,
    To get a 9.99 and quicker Competition Drivers Lic you need a full physical & EKG if over 60 years old and more cash.
    As for the fuel vent, I ran the same setup as old6 with no tech problems.
  14. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    NHRA just streamlined their cert / licensing proceedures, making it easier to compete.
    I don't know. Maybe its just me, but I think the older Fenn type chasses with a later attempt at glomming on an overhead roll cage look hideous. And they would not pass an NHRA cert without complete down tubes at each of the six points, not to mention vertical supports needed in the frame. Ask me how I know. My "Last Logghe" restoration now runs low tens, instead of mid-nines. Its just too much hassle for the few times I run that particular car at nostalgia / reunion events.
  15. Daniel Clark
    Daniel Clark
    On my tank I had a an fitting installed at the top so I could run a line down past the bottom of the tank with a non vented cap.
  16. I plan on running a line with a couple of loops in it,Thanks for the replies
  17. Harry506
    Harry506
    ImageUploadedByH.A.M.B.1460522902.859153.jpg ImageUploadedByH.A.M.B.1460522913.942294.jpg ImageUploadedByH.A.M.B.1460522924.960200.jpg ImageUploadedByH.A.M.B.1460522938.444941.jpg
    The Outlaw Lives.....
  18. Third DodgeBrother
    Third DodgeBrother
    Say what?
  19. Daniel Clark
    Daniel Clark
    I was just joking lol
    Sent from my SAMSUNG-SM-N910A using H.A.M.B. mobile app
  20. Harry506
    Harry506
    Got my first win last weekend in my $3200 race car...
  21. bobw
    bobw
    Winning is good! You should win best appearing car too.
  22. Harry506
    Harry506
  23. old sparks
    old sparks
    Went to Woodburn Oregon ( 14 hour tow) this weekend to run the oldies but goodies race. 17 inlines in the class ( inline / flathead ) . The facility and organization was hands down best I`ve seen. The people in the class were as nice as you can get. The entire facility was either paved or cut grass , you can`t get any better than that. With over 300 total car count, I still got in 8 passes. I would recommend this race and track to anyone
  24. Old28
    Old28
    I new you would be impressed with Woodburn. :D Great track, great people and a track crew second to none. :)
    How did you run?:eek:
  25. old sparks
    old sparks
    good to hear from you Tom. Quickest car was a hamb dragster at 11 flat , then Scott with a 11.24 and me with a 11.28. I pulled my usual and went out second round with an egg timer reaction. Still it was worth the total 28 hour drive just to meet the people and experience a fantastic track.
  26. Old28
    Old28
    Well Dan we are done with the relocation and re-model. Nice being home in Camarillo were we lived for 25 years.
    The stroke has my left eye still screwed up and not sure it will ever be normal. Like bobw says, the golden years are a bit tarnished. Hay I am learning to live with it.:D
    11.28 on your hot rod with the extra body weight and Scott with a 11.24 and a bare frame dragster got to make you feel good after a long tow like that. Real nice to know that after 8 years away from Woodburn the track and race group are the same as last time we ran our altered there. Real nice people.:)
    If you run down in Bakersfield, let me know, would love to see you run.:eek:
    Stay in touch buddy:cool:
  27. bobw
    bobw
    Unfortunately I'm not going to dip into the 11's at the Meltdown Drags in a couple weeks. Yesterday morning I went to the dermatologist and had a divot about the size of a quarter taken out of my cheek. I went from there to the hospital where they put me to sleep and removed scar tissue and enlarged the passageway in my prostate. Now temporarily wearing a bag. I probably won't be healed sufficiently to get all my stuff ready for the Meltdown. How's that for tarnished Golden Years?
    I'm looking for someone to run the dragster, with a for sale sign on it. Should get good exposure at the drags.
    Tom, I'm glad you have settled in and have the house the way you want it. Keep the faith, buddy. You might be back yet
  28. old sparks
    old sparks
    bobw, don`t give up yet. Even if it`s an occational test and tune. I`m 70 and am still able to force myself to go to the track , but once I`m in the car I get 20 years back
  29. 64 DODGE 440
    64 DODGE 440
    from so cal
    That pretty well sums up the whole thing. I'm also 70, but some mornings feel 90, though once I get my ass in the seat the years melt away. As the saying goes, "you are only as old as you feel". Unfortunately sometimes those feelings can kick you in the back side.
  30. millelacsrick
    millelacsrick
    Hi Bobw Sorry about your medical issues. Hang in there and get better. Please call me, MSRA #1780, maybe I can help you with the dragster.
