Features VINTAGE SPRINT CAR PIC THREAD, 1965 and older only please.
Discussion in 'Traditional Hot Rods' started by Joshua Shaw, Jan 17, 2008.
  1. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    Dean Lowe likes this.
  2. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    hornturner and Dean Lowe like this.
  3. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
  4. unassembled
    unassembled
    from San Diego
    I just finished rebuilding a USAC compliant 1957 Chevy 283 using the original Jahns aluminum pistons and stock crank. From what I discovered, engine builders of the day had to keep the cubic inch displacement to 305. That said, they could do almost anything else as far as cam, heads, intake and exhaust setups would go. Mine had an early roller cam which I did not use because of its inherent weakness. The heads were ported and polished, valve seat angles changed, and used stock valves, springs, push rods and rocker arms.
    We did little to the motor other than clean it, check the specs, hone and line bore, shot peen the rods, knurl the piston skirts, rebalance the crank and reassemble.
    It runs Hilborn mechanical injectors and cam driven fuel pump, a Lehman crank driven water pump. I installed a Schneider flat tappet cam and solid lifters.
    On the dyno, it cranked out 355 horsepower @ 6000 rpm and 347 ft lbs of torque @ 4500 rpm. Not bad for an almost 60 year old engine using the technology of the day.
    May not be the fastest, but it sure is pretty!
    Dean Lowe and 29 Speedster like this.
  5. DDDenny
    That's a beauty!
    The head on the pass. side appears to be a 69 and later head.
    What's the deal there?
    Again guys, I can delete this if offensive to the thread.
  6. BZNEIL
    BZNEIL
    That is pretty!!
  7. unassembled
    unassembled
    from San Diego
    No "deal". The heads are genuine 1957 Corvette Fuelie heads from the 3731539 stamping. Another indicator of early heads is that the valve cover hold down bolts are closer together on the intake side, than that of the exhaust side.
  8. jimmy six
    jimmy six
    I never knew that any 57 heads had a way of attaching anything. I remember the front of the left head and a lot of other cast in indicators but any place to use a cap screw...
  9. indyrjc
    indyrjc
    from Indiana
    Am I crazy or is that a front wheel drive car? At any rate I sure don't recognize the chassis.
  10. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    The f/r tires and radius rods tell me it's probably rwd. I couldn't come up with any info on the chassis either. If it was painted green it would look just like a big cucumber on wheels. :)
    ClayMart likes this.
  11. unassembled
    unassembled
    from San Diego
    After reading the replies to my recent post, I got to wondering about the mounting points on the head. So about 10:30 last night I drove over to the shop and pulled the valve cover off of the right head. This engine's heads are the 3755538 1959 Fuelie heads. We're building another engine for one of the other cars and it has the 1957 3731539 heads. I was going off of parts list rather than the build sheet. Sorry for the confusion.
  12. jimmy six
    jimmy six
    I learn something new everyday. Thanks
  13. IMCAbrat29
    IMCAbrat29
  14. The37Kid
    The37Kid
    ^^^^^^ Shaw car has an ARDUN, that is a hemi. Bob
  15. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
  16. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    Chuck Hulse #78, Bobby Marshman, Hoosier 100, 62. 3x-20-b-hulse marsh 62.JPG
  17. IMCAbrat29
    IMCAbrat29
    was it an aftermark for the Ford Flat head ? I was curious if it was one of Joshua's relatives.
  18. IMCAbrat29
    IMCAbrat29
    An amazing 800 pages of pictures and knowledge, I've enjoyed every page.
  19. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    Eddie Sachs and Tommy H., Reading.
  20. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    296ardun, Dean Lowe and slobitz like this.
  21. flatheadtommy
    flatheadtommy
    296ardun, carl s and Dean Lowe like this.
  22. flatheadtommy
    flatheadtommy
  23. flatheadtommy
    flatheadtommy
    IMCA driver Jerry Shumaker sets fast time at Bellville, Ks. 5/30/61 22.52 IMG_0419.JPG
  24. flatheadtommy
    flatheadtommy
  25. flatheadtommy
    flatheadtommy
  26. flatheadtommy
    flatheadtommy
  27. flatheadtommy
    flatheadtommy
    carl s likes this.
  28. flatheadtommy
    flatheadtommy
    carl s likes this.
  29. Speedwrench
    Speedwrench
    Might be interesting to hear the story behind this picture.
  30. Speedwrench
    Speedwrench
    I'll play, but this is a little before my time.
    Front row, second from left - Johnny Rutherford
    Front row, third from right - Gordon Wooley ( maybe Jerry Blundy )
    Middle row, second from left - Jerry Reichert
    Back row, middle in dark shirt - Jim McElreath
    Also in the front row there are three possibilities for Jud Larson
