Technical Need help with what fuel gauge
Discussion in 'The Hokey Ass Message Board' started by solo_909, Mar 19, 2016.
  1. solo_909
    solo_909
    I need some help, I have a 75-10 Ohm fuel sending unit what ohm range fuel gauge do I need? I can't seem to find one with the same ohms.
    Thanks!
  2. I am assuming you mean 73-10 ohms and they can be found at summit etc.
  3. solo_909
    solo_909
    No it's a 75-10
  4. I think it will work.
  5. Google 75-10 ohm fuel gauge, you'll see units at Summitt and elsewhere.
  6. Brand:Classic Instruments
    Manufacturer's Part Number:V8SR11SHC
    Part Type:Gauges, Analog
    Product Line:Classic Instruments V8 Speedster Series Gauges
    Summit Racing Part Number:CIN-V8SR11SHC
    Gauge Style: Classic Instruments V8 Speedster
    Gauge Type: Fuel level
    Gauge Face Color: Black
    Sending Unit: Electrical
    Gauge Range: Empty-full
    Gauge Size (in): 2 1/8 in. diameter
    Gauge Size (mm): 54.00mm diameter
    Sweep: 90 degree sweep
    Sender Ohm Range: 75 ohms empty, 10 ohms full
  7. Jalopy Joker
    Jalopy Joker
    post pics of your ride & type of gauges that you have now
  8. MengesTwinCustoms
    MengesTwinCustoms
    Speedway makes an adapter to run any fuel gauge with any sender, haven't used it but sounds like a handy product
