Projects Unearthing a StAr DeStroyer! 1931 Coupe w/394 olds-
Discussion in 'Traditional Hot Rods' started by Tuck, Jul 20, 2015.
  1. falcongeorge
    falcongeorge
    from BC
    I wont be using mine for a while, they are for my T-bucket, which I am forbidden to work on by both my wife, daughter, and several Hambers (who know me all too well), until my '39 is finished. See earlier post regarding my ADD and my daughters attention span...:p
  2. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    BAAAHHH! They're forcing you to work with a handicap. This is wrong... all wrong. USE THE FORCE.
  3. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    @falcongeorge
    They went together slick as shit! Took the spindles out of the freezer- put some anti-seize on and heated the adapters- slid them on with a pipe that fit the O/D- bamb- 15min later both spindles were done and had Buick hubs and drums bolted up! (-;
  4. falcongeorge
    falcongeorge
    from BC
    ^^looking good! Thanks Tuck.
  5. KustomCandy
    KustomCandy
    from Australia
    Yeah, This will smoke once done. Following!
    Dan
  6. Runnin shine
    Runnin shine
    Voice of Star Destroyer... "Where is my damn roller photo op?"
  7. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Right?? I know- the good news is while making progress on the roadster I made headway on the coupe. I'm running the same rear so the centering rings for the axle shafts/drums and the locating rings I made for adapting 12" backing plates I made double of so I have a set for the coupe. I'm running an olds rear in the coupe with buick drums too just because I love the looks of them so much. Will be a lot easier to convert that one though because I'm not changing the bolt pattern so I don't have to redrill the hubs. I am looking for a set of rear F-2 backing plates though! EDIT: I FOUND the backing plates! Now I'm just looking for an extra pair of Buick drums for the rear of the coupe.
    Tuck
    Outback likes this.
  8. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Started making my front and rear batwings for home made hair pins- drew these up on CAD and had the plasma table up the road slice them out of 3/8" flat stock.
    Also got a set of 4 15x6 5on5 steel wheels for the coupe as well...
    Outback, kiwijeff, hechtspeed and 6 others like this.
  9. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Inspirational pic...
  10. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Have everything tacked together- need to make the inserts for the bones. I bent and tapped the bones myself. Using two ends of f-1 drag links- the ends are different so I used two draglinks the hairpins I'm making for the rear will use the other matching pair. Really dig the looks of it so far-
    Tuck
    BigRRR, Outback, Vic Walter and 12 others like this.
  11. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
  12. Runnin shine
    Runnin shine
    Tuck i'm really hesitant to critique your work and creativity but... Have you considered minimizing the front axle inspired gussets to more closely resemble its spindly almost nothing left look? Like only using the middle and end shapes not the whole pieces that make up the capsule shaped long holes? Or just enlarging all three per hairpin?
    My best regards, Wyatt.
  13. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Wyatt- yeah I think the insert piece is going to have one hole the diameter of the opening of the hairpins and have that same radius on each side more like the axle- I think we're on the same page. I'll do some paper templates before I decide on the final.
    Tuck
    Outback, brad2v, Runnin shine and 2 others like this.
  14. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Runnin shine likes this.
  15. Love the hubcap choice, I am running those same Chrysler caps on my Model A.
    Hank37, hechtspeed, AHotRod and 4 others like this.
  16. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Cut up some 1/2 rod and turned and threaded the ends. Marked the center and bent them around a radius- then I bent it to flow with the axle- it's got about a half inch clearance everywhere I know it doesn't look like it in the pic. I'll make an insert for it with a tapered hole for the tie rod end.
    Outback, AHotRod and falcongeorge like this.
  17. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Ignore the backward spindle and the upside down shackle I needed that stuff out of the way when I was bending-
  18. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Was thinking something like this with a ball mount and chromed- Instead of running a bolt in ball I'm just going to weld a ball end in the gusset insert. Plan on running a 32 drag link to a f-1 box.
    Tuck
    BigRRR, Vic Walter, AHotRod and 5 others like this.
  19. I like it!
    Tuck likes this.
  20. Runnin shine
    Runnin shine
    Tuck are you going to make front and rear bumpers with the same tubular shape and gussets to tie all this look together?
    I love this build!!!
  21. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Not sure what I'm gonna do for bumpers- maybe... Maybe none!
    I'm gonna do another version (2.0) of the steering hoop tomorrow- (-:
    I have a couple more ideas I want to work out-
    AHotRod and Runnin shine like this.
  22. wheeldog57
    wheeldog57
    Tuck likes this.
  23. BCR
    BCR
    Haven't been online much.....awesome build.....best thing I have seen in awhile.
    Tuck likes this.
  24. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Here is a shortened version with a more squared off radius- makes more sense to me to cut it back- I dig the crazy hoop but it's too "far out" for this build.
    AHotRod, brad2v and kidcampbell71 like this.
  25. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
  26. 2nd version is way mo better!
    Tuck likes this.
  27. brad2v
    brad2v
    Agreed. 2.0 is the one.
  28. It's a good thing you shortened the arm 'cuz it takes a really long pitman arm to accommodate a long steering arm. Pesonally, I like quick steering achieved with a short steering arm and a long pitman arm but you can adjust both [or either] lengths to get the full lock and steering feel you like ...lookin good.
    Outback likes this.
  29. Looks great Tuck!
