Projects Home or hand made Parts, no price tags
Discussion in 'The Hokey Ass Message Board' started by topfuel55, Jan 10, 2013.
  1. Bulletnose26
    Bulletnose26
    Clutch and brake peddle assembly.
    3/8" steel. Bronze bushings and washers.
  2. topfuel55
    topfuel55
    from Hebron IN
    I'm dredging up my old post, hopefully folks will add some more stuff....I'm gonna add something I've been working on for a long time, a little bit at a time. The radiator sits lower than the engine in my car, making it impossible to totally fill the cooling system. So I built a top fill thermostat housing, with a quick release lid. It works on an eccentric to seal the oring. Once it over centers there is a pin lock. I'm machine buffing it then I'm gonna hand buff to soften the sheen. The pix are works in progress. ImageUploadedByH.A.M.B.1453133725.042623.jpg ImageUploadedByH.A.M.B.1453133755.182850.jpg ImageUploadedByH.A.M.B.1453133774.347772.jpg
    brEad and Stogy like this.
  3. DDDenny
    Gas pedal for my roadster, started out as Honda motorcycle brake pedal.
    mgtstumpy and Stogy like this.
  4. topfuel55
    topfuel55
    from Hebron IN
    Denny that thing is cool!
  5. DDDenny
    Steering column, tubing and scrap aluminum, machined and welded.
    Drop made from aluminum fuel motor con rod.
  6. Paul
    Paul
    Editor
    water cross-over to fit under Cragar 4-71 drive snout on 303 Olds
  7. squirrel
    I made a shifter a couple years ago, then decided to modify it to add overdrive, but also to make it work better. I reduced the size of the lever, so I could make the gates smaller, and add some extra stops to prevent missed shifts. Lots of wiring...which replaces the overdrive computer with a couple switches and a relay.
    mgtstumpy, Stogy, Woob and 1 other person like this.
  8. topfuel55
    topfuel55
    from Hebron IN
    Paul that is beautiful!
  9. topfuel55
    topfuel55
    from Hebron IN
    Squirrel, there is a lot going on with that shifter! What trans?
  10. squirrel
    TH400, switch pitch converter, Gear Vendors overdrive.
  11. DDDenny
    Shift boot riser made from thrift store aluminum pan, trim ring whittled out of scrap .
    Switch box made from electronics enclosure from surplus store.
    Corvette E-brake handle, cover from B&M shifter.
  12. topfuel55
    topfuel55
    from Hebron IN
    Here is another cooling system part. This will be paired with my four two barrel intake. The thermostat area is so small I'm gonna build a water neck and this will allow me to fill the cooling system for the highest point. The lever is an eccentric that over centers and locks.
    ATTACH=full]3110643[/ATTACH] ImageUploadedByH.A.M.B.1453136794.210514.jpg
  13. DDDenny
    Oops
    Shift boot is old Hurst IIRC, no longer being made.
  14. topfuel55
    topfuel55
    from Hebron IN
    ImageUploadedByH.A.M.B.1453137319.575539.jpg more cooling system parts. This is a overflow tank for more car. There is a pin lock that allows the top to open. Hidden inside is a stand pipe to allow pressure relief and if the coolant get too high it can vent out of the stand pipe. The steel bracket will weld to the frame and then the tank will bolt to the bracket.
  15. fadt
    fadt
    from England
    Fuel tank and steering wheel. Both hand made from scratch.
    Steering oct 08 (11) [640x480] (2015_11_13 11_07_31 UTC).JPG Steering oct 08 (20) [640x480] (2015_11_13 11_07_31 UTC).JPG
  16. topfuel55
    topfuel55
    from Hebron IN
    ^ nice! Always wanted to build a steering wheel and the star tank is really cool!
  17. topfuel55
    topfuel55
    from Hebron IN
    Another shot of the gas filler for the car. I have a fetish for eccentric locks.
  18. DDDenny
    Never liked the whole "arm hanging out the side of a hot rod" deal. Also hated clubby steering columns and turn signal levers, so I made turn signal switches out of Hurst line-loc switches, tied in with a hidden, self cancelling signal box.
    Stogy, charleyw, olscrounger and 2 others like this.
  19. DDDenny
    Hairpins, ladder bars, sway bar, rear panhard bar, pedals, column support, steering shaft support, motor mounts, clutch pivot pieces, tubular firewall legs, nerf bars and mounts.
    These are mostly non purchased pieces, the pedals and sway bar arms were bought but detailed with drilled holes. Everything is plated in low lustre brushed nickel, the plating did have a price tag though.
  20. rusty rocket
    rusty rocket
    I made this hidden gauge and heater, a.c. control DSC02865.JPG compartment from an old heater housing.
    mgtstumpy, RICH B, Stogy and 3 others like this.
  21. oj
    oj
    You've really got that latching stuff down, how about a thread to show the mechanics, angles and linkages to make them work?
    I too have a modified, they are so tiny everything has to be made and since there is so little space I decided to add a little luggage rack to the top of my gas tank before the tank gets painted. It is stainless steel - this is a work in progress shot I took yesterday after tackwelding the rear bracket to the tank. I was figuring how to make the front supports and it has to be removable. Only 2 of the 4 rods are sitting in place, tag light/backup light is '50s JagXK120, steel channels are for leather and stainless tank straps. DSC00959.JPG DSC01468.JPG
    Stogy likes this.
  22. topfuel55
    topfuel55
    from Hebron IN
    Oj, that tank and rack is cool! The modifieds do have to have hand made parts. I learned that early on with mine. Everything looks out of scale.
    This is the latest parts I'm working on and two twos intake for my new 283. All kind of stuff to run no hole cal custom VC's. Oil filler, fuel block, new throttle cable mount. ImageUploadedByH.A.M.B.1462851563.179797.jpg ImageUploadedByH.A.M.B.1462851579.636359.jpg ImageUploadedByH.A.M.B.1462851605.447253.jpg
    mgtstumpy, Stogy and oj like this.
  23. Donut Dave
    Donut Dave
    I made (2 sets) of wheel stands in 2006 with the intentions of marketing and retailing. After considering the liability involved I scraped the idea. They sure are handy, before I was using jack stands but they were always in the way and never high enough to use a roller creeper. unpainted stands (239 x 360).jpg IMG_3706 (2736 x 1536).jpg IMG_3708 (2736 x 1536).jpg IMG_3707 (2736 x 1536).jpg
    mgtstumpy, Stogy, charleyw and 2 others like this.
  24. OK I'll play I made this setup a few years back, shortened the housing, made all the 4 link brakets and the drive shaft hoop. I don't have a pic but I went on to shorten and balance the driveshaft while I was at it.
    While I am thinking about it these are not to technical but I made these jack stands for when modern jack stands just won't do.
    This aint much either but this carb cover is made from the air cleaner end cap for a Gardener Denver screw compressor. You can't see it but I also made the base plate.
    These don't look lie much but the Raven and I made these headers last minute ( literally) from a 15 dollar set of swap meet headers cut up and fit to the roadster.
    This could be considered billet but I carved this gauge panel from a piece of aluminum plate a few years back, the gauges are sunken so that a set of SW gauges the bezels are flush with the face.
    Hey this is fun I have found pics of stuff I have built all over the place. LOL
    Stogy and saltflats like this.
  25. Blue One
    Blue One
    from Alberta
    View attachment 3214322 View attachment 3214323
    I copied your idea, and I added some skateboard grip tape to the top surface. They work really well.
    As for other handmade parts, there are loads of them on my build thread.
    http://www.jalopyjournal.com/forum/threads/26-t-roadster-pick-up-build-thread.460009/
  26. Built the blower drive, idler brackets, idlers, carb adapter, rear blower plate
    Not a part but a tool......
  27. [​IMG]
    Made the air cleaner insert, topper and shiftknob in this photo
    Made this shiftknob out of the parts shown
    Made an overflow out of this old top oiler I found for $2
    mgtstumpy, Stogy and cretin like this.
  28. cretin
    cretin
    Here are a few things I've made pretty recently
    This is a handle for a hood latch release cable. The center of it functions as the button to allow you to push or pull the cable.
    Some taillight trim out of brass.
    And a column drop.
    JimBeam, dualquads, mgtstumpy and 5 others like this.
  29. Fatbrosracing
    Fatbrosracing
    from Australia
    Here's some recent fiddling, drink bottle made into radiator overflow, stainless steel 37 Ford trunk prop, I like making stuff from scrap ally to look like castings, fuel pump block-offs are a good use of scrap. IMG_0516.JPG IMG_2007.jpg IMG_1971.JPG IMG_2226.jpg IMG_1114.jpg
  30. Merlin
    Merlin
    from Inman, SC
    Did the same thing only with 2x10's.
