Hemi lasalle transmission setup. Early extended bell hemi to lasalle transmission adapter with a sideshift trans and new clutch,pressure plate, thowout bearing and a good used cast iron flywheel. Also included is a Hurst shifter I was told will work with this trans, but looks like it will take a little fabrication to mount it. Trans rotates and goes into all gears good. Flywheel is still on engine, but I will remove it and add pics in the next day or so. $750 Hummelstown PA 17036 I do not really want to ship this, but I will if needed. Pics here:http://s896.photobucket.com/user/buikspecial56/library/Lasalle
