Hot Rods THREE SPRINGER , 3 SPRINGER picture thread
Discussion in 'The Hokey Ass Message Board' started by bct, Apr 24, 2011.
  1. Olson
    Olson
    Even with the belly that looks like one helluva tight fit...almost makes ya think those guys are all standing there trying to figure how to get him out. Haha
    volvobrynk likes this.
  2. bct
    bct
  3. Bigcheese327
    Bigcheese327
    Jimmy B and volvobrynk like this.
  4. bct
    bct
    Yes i read the article and the comments are entertaining.
    Nice work.
  5. orangeamcs
    orangeamcs
    Have collected all my parts I think by this point. looking for more pics like the spasmodic car. I have a lot of work to do with proportions to make it look right. Also trying to decide what grill to use. Also trying to decide how much to narrow frame and body.
    26 touring body
    wavy dodge front axle
    model a drivetrain
    27 chevy frame.
  6. alchemy
    alchemy
    That sounds like the recipe I am following, except I am using a flathead 8. I narrowed the body 6 inches on mine. Hopefully mine has the profile of the Garrick car when done.
  7. orangeamcs
    orangeamcs
    bct likes this.
  8. rusty rocket
    rusty rocket
    Lil'Alb, 69thumper, clem and 5 others like this.
  9. KKrod
    KKrod
    Here is a neat old modified. Do you know of anyone who has built a one man car for the street? Would be interesting to drive... s-l1600 (2).jpg s-l1600 (3).jpg
    Lil'Alb, cactus1 and Okie Pete like this.
  10. orangeamcs
    orangeamcs
    What spindles did you use on the wavy axle Rusty rocket?
  11. rusty rocket
    rusty rocket
    47 Ford.
  12. orangeamcs
    orangeamcs
    What did you have to do to make them work
    Sent from my SM-G930V using The H.A.M.B. mobile app
  13. rusty rocket
    rusty rocket
    Reamed the axle to accept ford kingpins. Used the dodge kingpin retainer bolt instead of the ford, I milled a flat spot on the kingpin so the dodge bolt could lock the king pin in. After spindles and hubs were on I took everything to a truck alinement shop and had the axle bent to get everything where it had to be.
  14. orangeamcs
    orangeamcs
    What spring hangers were used for the rear of the front springs when they were moved outboard and does anyone have detail of how they made the support or crossmember for the front of the dront springs. Also i think im going to narrow my frame to about 20 inches give or take. I think tbats in the ballpark. I am open to any suggestions.
  15. bct
    bct
    I just spun my spring hangers 180° then made a spacer plates to adjust my springs parallel . I still need to add a triangular gusset.
  16. bct
    bct
    I used quality 9/16 fine ready rod for the front spring mounts. Slid some dom between the stock hangers on the frame horns.
    20 inches sounds good. I made mine 22 and I wish I went narrower.
  17. KKrod
    KKrod
    I was going through the photos on my computer and found these I had taken back in 2007 at a car show in Fort Worth. Here are several shots showing the front spring setup on Phil Weiand's old T. Also shows a body mount bracket on the cowl. RearView.jpg FrontView.jpg AxleMount.jpg BodyMount.jpg FrameDetail.jpg RearDetail.jpg SpringMount.jpg SpringMount2.jpg
  18. Pictures please?
  19. alchemy
    alchemy
    I haven't mocked any of mine up into a car-like shape yet. Still working (relative term) on patching the body. Will probably have more new sheetmetal than original by the time all the rust is gone. I'll start its own thread when I get to some actual photogenic progress.
    bct and cactus1 like this.
  20. Bigcheese327
    Bigcheese327
    I prefer the cut-down body on the Weiand car. I had no idea it still existed.
    Okie Pete, Carter, KKrod and 2 others like this.
  21. orangeamcs
    orangeamcs
    Here is what I have so far
    Lil'Alb, Okie Pete and bct like this.
  22. Beau
    Beau
    Next...been a while after our move but I'm getting closer. T Roadster. B engine. '28 Chevy frame. Franklin axle. Oddball Whippet shell. The rest as it comes. 20171203_204039.jpg 20171203_204107.jpg
    Lil'Alb, brEad, Okie Pete and 5 others like this.
  23. Six Ball
    Six Ball
    from Nevada
    Like it. Nice parts collection it will be fun.
  24. JakesA
    JakesA
    Updates from any constructors and/or enthused ones?
  25. Gary Addcox
    Gary Addcox
    I am wondering if late '20s Plymouth/Dodge wavy tube axles qualify for use? They were equipped with hydraulic brakes and utilize dual leaves. Anyone ?
  26. dumprat
    dumprat
    from b.c.
    I have a 1930 Plymouth axle. It has about the same drop as a2.5" drop 34 ford axle is absolutely gorgeous in construction. Smooth and nicely welded.
  27. Six Ball
    Six Ball
    from Nevada
    100_0883.jpg I have one that I bought a home built trailer to get many years ago. It's still there because I got caught up in using the trailer around the place behind the tractor. But someday .........
  28. orangeamcs
    orangeamcs
    made alot of progress on mine this past week, basically started with frame rails and in 3 days steve pugner and had built a whole car.
  29. orangeamcs likes this.
  30. What wheelbase did you end up with?
