Technical ford 9" in a 1963 chevrolet biscayne
Discussion in 'The Hokey Ass Message Board' started by 55 dude, Jul 12, 2015.
  1. guys does anyone make the brackets to bolt the 9" in? actually a triangular 4 bar instead of 3 bar would be prefered! thanks!:)
  2. 41hemi
    41hemi
    Maybe try Currie.
  3. Deuced Up!
    Deuced Up!
    Might be a start?
  4. thanks! anyone else? anymore pictures?
  5. currie and mosiers didn't have any, can anyone else think of anyone else?
  6. squirrel
    If it were me, I'd cut the brackets off the original housing (or find a spare housing) and weld them to the new housing. But I'm cheap....
    slammed likes this.
  7. 56sedandelivery
    56sedandelivery
    Chassis Engineering has all kinds of mounting brackets and suspension pieces. That's where I'd start if I was going to assemble my own setup. I am Butch/56sedandelivery.
  8. 2racer
    2racer
    http://www.currieenterprises.com/cestore/productsRE.aspx?id=2495
    59-64 CHEVY FULL SIZE CAR HOUSING BRACKET KIT
    NOTE: Sample image only,
    actual product may vary.
    Part #: CE-7059A
    Our Price: $172.95
    Description: New reproduction rearend housing bracket set for 1959-1964 Chevy full size cars. Includes single upper control arm mount, both lower control arm mounts, panhard rod mount, and brake bulkhead fitting tab. Fits all Impalas, Belairs, Biscaynes, Delrays, Station Wagons, and '59-'60 ElCaminos.
  9. cool! i will let my friend know they are available
  10. i'm cheap myself but it seems like all the fitting really extends the job, currie is really proud of those brackets!
  11. $173 out of pockets beats $500 worth of aggravation and you'll probably save 1/2 of the $173 in beer that was not consumed in the process.
  12. squirrel
    I guess I just do everything the hard way...maybe I should start charging myself for aggravation? But the weird thing is, I see it as just another fun challenge.
  13. saltflats
    saltflats
    from Missouri
    If he is going to try and get on it with the big block he will want the other upper arm and bracket to get a handle on the wheel hop.
  14. Gman0046
    Gman0046
    To me $173 is a steal. Not worth your fab time.
  15. slammed
    slammed
    Yes. When your good, resourceful, and patient this is the way to old school it right.
  16. sunbeam
    sunbeam
    Remember when Hot Roding was fabing not buying kits?
  17. gimpyshotrods
    gimpyshotrods
    Maybe I missed it, but what is wrong with the stock axle?
  18. indyjps
    indyjps
    Agree, I used to reverse quote and negotiate fabrications, those brackets are about $12 each, the welded one a little more, that includes overhead. Ya gotta have a laser and press brake with a dogleg tool to do em in 1 piece like that. I'm happy someone offers them, think I'll look at more options before hitting the buy button.
    the housing mounts don't look to bad to do, the top angle mount more difficult to get the angle correct to hole location. Could probably use structural tube and measure up the old axle well.
    A business will buy the kit considering they need $50-$150 an hour to cover labor and overhead, a garage builders time is not so high.
  19. Ramblur
    Ramblur
    The tough part is the lower brackets. The lower hole is also the shock mount and as such the hole facing the outside is keyed (partial flat in the hole) to locate the shock mount and prevent it from rotating. The inside hole needs to be a very snug fit as the shock mount end of this lower trailing arm bolt is splined like a wheel stud and needs to get a good bite on the lower bracket hole, again to prevent the shock mount from rotating. Seems odd that I don't see this keyed hole in Curries pic above. Chev63.JPG
