Technical 460 Starters got my hair going grey. What to do?
Discussion in 'The Hokey Ass Message Board' started by FFFFrank, Jun 16, 2015.
  1. FFFFrank
    FFFFrank
    Alright, so my early '70s 460 is a pretty mild build but the stock starter (Lester 3152) has a lot of problems turning it over when slow. It barely cranks (feels like a dead battery) for 5-6 turns and then finally kicks it over. Researching online it looked like the solution was to upgrade to a PMGR unit out of a 90s truck (Lester 3226.) Bought a brand new chinese unit. This seemed to solve all my problems but the bendix on the new starter went out. Took it into my local shop and the guy rebuilt it and assured me that "this time he used american parts."
    Worked for a few weeks and then the starter stuck, roached my flexplate, burned up something inside the starter and wrecked the bendix drive gear. Back to the rebuild shop. Motor and tranny out. New OEM 164-tooth flexplate back in. Checked and double-checked my clearances. Started it up, starter stuck on immediately. I wanted to be sure the metal on metal sound was the starter so I pulled it out with the engine running. Bendix was shot again, starter was hot as hell. Metal on metal sound stopped.
    I'm 99% sure my wiring is correct for the PMGR (battery to left side of fender mounted solenoid to big starter terminal, right side of solenoid to small starter terminal.) I know the flexplate is good and has the right tooth count.
    I'm back to the OEM starter and my embarrassing slow whrrrr...whrrr....whrrr...... before it cranks over. What's next?
  2. onetrickpony
    onetrickpony
    from Texas
    Sounds like a bad ground problem to me. Low voltage due to a bad ground can cause all of these problems you have had. The low voltage causes arcing which causes sticking which takes it's toll on everything.
  3. FFFFrank
    FFFFrank
    Starter grounds through the mounting bolts. Hard for that to be bad. Battery terminal and ring are clean but I'll check the block end and see what might be up.
  4. FrozenMerc
    FrozenMerc
    Yes, but do you have a ground strap going from your motor to the chassis, or is the ground side of the battery grounded directly to the motor??? Rubber engine mounts don't do a good job of conducting electricity.
    Also, what gauge of battery cables are you using? Are they getting hot as well?
  5. coolbreeze1340
    coolbreeze1340
    from Indiana
    x2 on the grounded engine with large cables. I have a 429 and the starter does the "slow roll" but it always starts.
  6. onetrickpony
    onetrickpony
    from Texas
    There have been times when I have run a ground cable from the starter mounting bolt all the way to the battery. This was on a car with a battery in the trunk. It was the only way I could bet the danged thing to start consistently.
  7. trollst
    trollst
    All my stuff is grounded from the battery to the block, the closer to the starter the better. Ground engine to battery, engine to frame, engine to body, body to frame, that should handle the ground situation.
  8. FFFFrank
    FFFFrank
    Tried playing around with a section of 0-gauge ground wire and wasn't able to make anything work better (or worse.)
    Was at my starter rebuilders today and asked them and they said that the 460s can be really hard to start if there's too much timing in them. I haven't checked mine (timed it by feel) but sure enough, unplugging my dizzy caused it to fire up faster than a hurricane toupee. I'd had to retard it out just so it starts but what are the chances that's the real problem?
    Why would unplugging my dizzy magically make the starter spin faster? Just two things drawing voltage at the same time? Does this help or hurt the idea that I need bigger cables?
  9. 69fury
    69fury
    I'd put a kill switch on the ignition- crank it up then add spark...
  10. Engine man
    Engine man
    from Wisconsin
    Or put a button to crank the starter then turn the key on. Timing by ear usually gets you too much advance. Check the vacuum advance. You won't have much vacuum when cranking so the timing will be backed off. Once the engine starts the vacuum advances the timing also,the mechanical advance kicks in as the engine speeds up. If the vacuum advance doesn't work, you will have set the timing very advanced when timing by ear. If you have one of the dual diaphragm distributors you might want to find a single diaphragm unit.
