Technical Bango Rear 28-31
Discussion in 'Traditional Hot Rods' started by Danshotrod, Apr 15, 2015.
  1. Danshotrod
    Danshotrod
    Looking for any and all info on how to remove the torque tube from a 28 31Ford Bango rear. My buddy is looking to convert it to open drive shaft. Any diagrams would be helpful. thanks Dan
  2. Danshotrod
    Danshotrod
    ImageUploadedByH.A.M.B.1429188552.659605.jpg here is what we have
  3. Hot Rod Works.
  4. butch27
    butch27
    Do a search here. Great write ups are already on here.
  5. 117harv
    117harv
    To do an open drive on a model A banjo will require some work. The drive shaft is a tapered and keyed fit into the pinion, you would need to take off the driver side axle tube to access the castle nut and cotter pin. Once the drive shaft is out, it would need to be cut and have splines machined, your choice to match the yoke you plan to use. Then you would need to make a custom cap to keep oil in the rear, it will also need to have another bearing as the A banjo only has one.
    stillrunners likes this.
  6. Model A Gomez
    Model A Gomez
    Speedway has an open drive conversion for a Model A for $300, the rear end in the picture isn't a Model A rear end. Once you have converted it to open drive you will need to do something with the wishbone
  7. My 355 S-10 has a bango rearend. Not long ago it went "bang", no it don't "go"
  8. 117harv
    117harv
    The rear in the pic, is a model A or early 32, they are the same sans axle tubes.
  9. 117harv
    117harv
  10. oj
    oj
    I made one once, it was pretty easy if you have a lathe. I don't think I'd do it again because of the unsupported pinion, I think they need the torque tube to help support them.
  11. TBone69
    TBone69
    from NJ
    Think
    Check out the following thread over at the Ford Barn, this should get you in the right direction
    http://www.fordbarn.com/forum/showthread.php?t=22691
  12. Kiwi 4d
    Kiwi 4d
    Sorry but why would you do it. If you plan to go open drive , means you will probably have more HP than stock, so why not go the A v8 diff route and ft a HRW conversion to a V8 diff. More ratio choices and stronger.
  13. Danshotrod
    Danshotrod
    ImageUploadedByH.A.M.B.1429272263.921881.jpg ImageUploadedByH.A.M.B.1429272305.722603.jpg this is the car that it's all going in
  14. denis4x4
    denis4x4
    from Colorado
    You can use the stock wishbones by putting a reinforcing strip on the weld seam DSC03437.JPG
