Technical 1954 Ford - Carb issues
Discussion in 'Traditional Hot Rods' started by FiftyFoFord, Aug 13, 2014.
  1. FiftyFoFord
    FiftyFoFord
    I have a 54 Ford sedan, today, the carb caught fire. It was my own fault for not re-building it and repairing the leaks.
    It's a simple single barrel carb, does anyone have any experience using anything other than the Holley 1904, that came standard on the 223?
    Debating replacing/upgrading, but not quite sure which direction to go.
    Thanks in advance for your help
  2. 59'er F100
    59'er F100
    from Duncan, OK
    As you know there are a number of intakes that offer the possibility 2 bbl or 4bbl carbs of that is a way you want to go. I don't believe there is a direct replacement though. If you want to get rid of your 1904, I'd sure be interested.
  3. JeffB2
    JeffB2
    from Phoenix,AZ
    There is one other thing that comes into play,the 1904 is made to work with your Load-O-Matic distributor.If you can find a pre-1964 Ford single barrel with a matching bolt pattern you could go that route. This picture might get you thinking to "kick it up a notch" ;) 223.jpg
  4. 59'er F100
    59'er F100
    from Duncan, OK
    Hell yeah!!! What are are those air cleaners off of???? This is the route I'm going with my 223! Way cool brotha!
