Art & Inspiration WILD PIPES...cool and crazy headers picture thread
Discussion in 'The Hokey Ass Message Board' started by Kiwi Kev, Mar 25, 2015.
  1. Phillips
    Phillips
  2. Thanks to Elgringo (post#65) for posting Ted Coopers coupe "Pipe Dream"
    els and elgringo71 like this.
  3. elgringo71
    elgringo71
    No problem, thanks for filling in the blanks on who owned the car. Here is another picture that belongs here. image.jpg
    Stogy, Martin Harris and kiwijeff like this.
  4. Marty Strode
    Marty Strode
    Kev, This is the second set on the same car, a few months later. 2012-07-19 113420.jpg
    Stogy, cruiserjohn76, els and 2 others like this.
  5. Marty Strode
    Marty Strode
    I built these for a flathead powered Bonneville roadster last year. IMG_4334.JPG
  6. rfraze
    rfraze
    Early step headers!
    els likes this.
  7. Larry T
    Larry T
    How about some "factory built" pipes. I'll probably cut them up and use them to build or modify other headers withl headers.jpg headers 2.jpg
    Stogy and els like this.
  8. wsdad
    wsdad
    I think I may have a couple more pictures around here somewhere... 58496_orig.jpg 84085_orig.jpg 405459_2970600698071_156312.jpg 407452_2970599698046_381855.jpg 994107_693810837308485_1498989405_n.jpg 1341665_orig.jpg 1519823_orig.jpg 1905280_orig.jpg 2199978_orig.jpg 2663842_orig.jpg 3032998_orig.jpg 3147587_orig.jpg 4235254_orig.jpg 4342188_orig.jpg 4438883_orig.jpg 4746952_orig.jpg 5050078_orig.jpg 5232684_orig.png 5275753.jpg
    Stogy, els, hendelec and 3 others like this.
  9. wsdad
    wsdad
    5564073_orig.jpg 5657850.jpg 5657850_orig.jpg 6479120_orig.jpg 6553061_orig.jpg 7169637.png 7309123_orig.jpg 7437095.jpg 7437095_orig.jpg 7591986_orig.jpg 7725560_orig.jpg 7963475_orig.jpg 8089880_orig.png 9056822_orig.jpg 9121294_orig.jpg 9612302_orig.jpg 9657321.jpg 9657321_orig.jpg attachmentE1BZX0F9.jpg Dragsters-of-late-19500064.jpg Dragsters-of-late-19500066.jpg More... 5564073_orig.jpg 5657850.jpg 5657850_orig.jpg
    Stogy, els, Martin Harris and 2 others like this.
  10. wsdad
    wsdad
    Still more...
    stuckey.jpg untitled.png untitled2.png untitled3.png untitled4.png untitled5.png
    Stogy, els and kiwijeff like this.
  11. wsdad
    wsdad
  12. ARNIE
    ARNIE
    "High Times"- Stainless
  13. wsdad
    wsdad
    I've wondered the same thing.
    There seems to be a lot of pictures of cars from that era from around South Texas . Maybe it was a local style? Although I have seen pictures of long-headered cars from other places too. Maybe various people just thought it looked cool.
    Or, maybe it had something to do with Ed Iskenderian's, "5th cycle" cams - helped scavenge exhaust?
    I'm just guessing. Anyone know for sure?
    els likes this.
  14. Longer tubes on say a set of zoomies would move your power band down a little bit in the RPM range.
    A set of zoomies like are the most popular these days have a tendency to make it lay down on the bottom end where as a longer tube will salvage a little bit of the bottom end while giving up a little on top.
    I am not sure that is why we are seeing them in this thread but that is the basic theory behind it.
    els likes this.
  15. wsdad
    wsdad
    What would tapered headers do to the power band or scavenge effects?
    els likes this.
  16. els likes this.
  17. wsdad
    wsdad
    I think you hit the nail head right on the nail head. :)
    els likes this.
  18. Larry T
    Larry T
    I believe the Ramchargers used tapered pipes (megaphones) because of a technical paper Norton put out about the optimum length and taper on their motorcycle pipes. But I could be wrong. I don't think you'll ever get individual pipes to scavenger like a header with a collector on it.
    els and loudbang like this.
  19. You are correct PB. This is the "organ pipe" principle. Longer tubes will have a lower resonant frequency. At a certain frequency the natural resonance will put a negative pressure at the exhaust port at the proper time to match the exhaust stroke of a certain engine RPM. So, longer pipes are "tuned" to a lower engine speed.
  20. pitman
    pitman
    A tapered pipe, I've read lowers the exhaust note.
    els likes this.
  21. i love this thread!
    Stogy, els, patmanta and 2 others like this.
  22. Marty Strode
    Marty Strode
    Dragster stuff. 2013-10-13 132314.jpg 2013-11-07 110838.jpg BD4.jpg Duedall & Marrs San Gabriel \'62.jpg
    Stogy, cruiserjohn76 and els like this.
