The Flaven & Flaven Model A build.
Discussion in 'Traditional Hot Rods' started by Pete, Nov 23, 2014.
  1. BAD PENNY
    BAD PENNY
    from mass
    Lookin' good so far Pete !!! Finally something to follow. The brother thing worked out pretty well for me in my re-do. Good luck. Brett
  2. Pete
    Pete
    ImageUploadedByH.A.M.B.1417908825.242099.jpg ImageUploadedByH.A.M.B.1417908864.054559.jpg ImageUploadedByH.A.M.B.1417908886.869501.jpg
    We had some time yesterday to to trim the box cross member to make room for the S-10 tranny tail shaft and make a rear K member. Mike wanted to use beefy 2X3 rectangular tube stock and slide the rear portion inside the frame. I'll reinforce the areas that were removed for the tranny later. We also made the dropped tranny mount using 1X3 tubing. Rather that cut the tube and weld each piece we figured out the drop and the width, pie cut the top and the two sides, than we bent the tube and closed the gap leaving only 3 sides to weld.... Just need to drill a few holes and the mount will be done.
  3. flatoz
    flatoz
    looks good, are my eyes not seeing right, or is the rear bottom edge of the rail removed? Can I see the garage floor?
    I like that your using the original centre member but beefing it up, thats cool
  4. Pete
    Pete
    Your eyes are correct.... That's all going to be plated, boxed and welded.
  5. Swiss50chevy
    Swiss50chevy
    where will the rear axle hump land body?
  6. 3wLarry
    3wLarry
    from Owasso, Ok
    patiently waiting
    kidcampbell71 and volvobrynk like this.
  7. Pete
    Pete
    The model A Brookville body is set up for the model A or 32 frame so it already has a kick up in the rear floor.... But moving the rear cross member forward 7 ish inches won't harm anything, it'll just move the hole forward the same amount.
  8. Lookin good Pete!
  9. The best part of following THIS thread is, when the car is finished I'll get to see it on the road.
  10. Pete
    Pete
    We had some time to work. Got the rear wishbones figured out and welded, well gusset and plate the heim joint area.
  11. Pete
    Pete
    Pic
    volvobrynk likes this.
  12. wheeldog57
    wheeldog57
    nice start pete lookin sporty. i like the single heim joint on the radius rods. you and ray and a bunch of others are reversing the axle tubes, what is the advantage? mine is a 36-37 w/ spring behind and i added 7 1/2 in to the frame to make it fit
  13. Pete
    Pete
    In my opinion it's easier to shorten the frame that it is to lengthen it... So be reversing the tubes the wheel base doesn't change.. Just one approach I guess
    patmanta and volvobrynk like this.
  14. gonzo
    gonzo
    Looks great!
  15. Pete
    Pete
    Picked up the 31 roadster body... Wouldn't fit inside the truck with the utility cap... so on the roof it went...
  16. Pete
    Pete
    Didn't waste any time.
    The body from brookville is set up for either stock model A or a 32 frame. Our frame is Z'd so we had to trim some of the sub rails as needed. We also added a new cross brace which replaced the one that was removed.
    volvobrynk and patmanta like this.
  17. Pete
    Pete
    Body on the frame.
  18. Pete
    Pete
    Spent yesterday on the car with Mike. Taillights installed. Started on the steering. Trimmed and fitted an F1 box to fit inside the A rails. Shortened the shaft and changed the spline to fit a different wheel.
    The upper shaft was solid and the F1 is hollow so I turned the upper down to snugly fit.
  19. Pete
    Pete
    Finally starting to take shape.
    bymanr likes this.
  20. HELLBILLY
    HELLBILLY
  21. looks great Pete
  22. onekoolkat1950
    onekoolkat1950
  23. Pete
    Pete
    Hopefully today I'll get the steering completed.
    Than onto the pedals.
  24. Shamus
    Shamus
    from NC
    Nothing like a pipe rack when U need a little extra space - looking good, Pete.
  25. Pete
    Pete
    Thanks shamus.
  26. Pete
    Pete
    I tried to talk my bro out of the model A box, told him they get removed for a reason. So yesterday we spent about 4 hours fitting the A box, got it all done and guess what...? Yup, it sucked!
    Ripped it all out this morning and....
    Played with the steering today. Squeezed an F1 box right into the stock model a steering hole. Had to trim the F1 flange a bit on the top two holes, cut the bottom bolt hole completely off and re drilled it. Fits nice.
    Shortened the drag link but just tacked it this time.
  27. titus
    titus
    Whats the plan to extend the frame to support the back of the body? They seem to have had trouble cracking all around the body mount from the weight of the body from the factory? some tubing in teh subrials maybe?
    Cars lookin good.
    JEFF
  28. Pete
    Pete
    Jeff.... That's the plan. Not sure if it's going to be round or rectangular tube. But it will definitely need something.
  29. wheeldog57
    wheeldog57
    hey pete, looks great! thanx for the detailed pics of steering box mount and linkage. i will be tackling that pretty soon that body is nice, you dont hafta worry about getting a tetanus shot!
  30. titus
    titus
    sure, cool. or wood...like a model A truck bed has.
