I got a block and the crank, pan, and pistons are all I have and are assembled. I need all the rest. If anyone is near by (Roseville, CA) and has anything let me know. Thanks you Posted using the Full Custom H.A.M.B. App!
Hey Cory, I've seen a few posts on here in the past while searching for other 49-52 Chevy stuff. You might want to do a search, if you haven't already, to see where some other hamb'ers get GM in-line 6 engine parts. If you don't have any luck locally. You might want to check out these two companies, again, if you haven't already. Just a thought, best of luck with your engine build. http://www.patricksantiquecars.com/ http://www.langdonsstovebolt.com/ Adam
Cory, I have a late 50's hydraulic cam 235 listed in the classifieds..... $250.00 I think it is. It is a sweet running motor, starter, gen, carb..... could start it sitting on the floor It has a 4 spd truck trans mounted to it too.
