Hot Rods "The Abomination" Henry J gasser- on the operating table
Discussion in 'The Hokey Ass Message Board' started by Von Hartmann, Feb 2, 2010.
  1. Von Hartmann
    Von Hartmann
    So the Henry J is due for some serious TLC. Some of the guys on here already know that shortly after last years Hunnert Car Heads-up I had some trouble and Hydrauliced the motor. Something went bad in the carb and it dumped gas into the motor. Whent I went to start it, it bent up number 8 rod. Hurray for Holley carbs.... This was last september, I just pulled off the head and found that the intake runner was still filled with gas.
    I have a whole list of things on the To-Do list. I have rearend work to do, work to the front clip, some interior work, and test fit a B&M Hydro Stick Trans in it. But most of all, engine rebuild the motor is a '68 327 bored .020 over. current trans is a TH400
    Here's the rod
    The motor made one half revolution and lodged the piston against the crank counterweight. Looks like I got lucky. No visible cylinder wall damage. The rods were stock, so I believe that may have saved my ass. A forged rod may have stood its ground and took it out on somethin else.
    The steel tilt clip is easy to remove for these kinds of things
    And out comes the motor
    When I built the car, I swiss cheesed the crossmember to make it easy to drop the pan. Otherwise the motor has to be pulled. The holes not only lighten, but make it easy to access the pan bolts.
    So the motor will be completely tore down. I just ordered some forged I beam rods. I'm going to replace the one piston. The pistons are Keith Black Hyperutectic 10-1 pistons. They will hopefully hold up. I'm going to obviously rebalance the motor and while I'm at it I plan to do a cam swap to a solid lifter Isky cam and do some port work on the heads. Re-ring it, new bearings, and some minor dress up stuff.
    Deuces likes this.
  2. Von Hartmann
    Von Hartmann
    When I got the motor out, I decided I didn't like the way the motor mounts looked.
    So I boxed them and put a sleeved hole through to make it look cool
    I felt like drilling holes in something heavy and my brake pedal lever looked like it could use some.
    Much better, lighter too, yet still plenty beefy
    Deuces likes this.
  3. Royalshifter
    Royalshifter
    Moderator
    Awesome.
    Deuces likes this.
  4. Lookin' good, That rod is a work of art. Will you be ready for the Hunnert?
    Deuces likes this.
  5. Von Hartmann
    Von Hartmann
    I hope to be ready for Torque fest on May 1st
    Deuces likes this.
  6. Stick Shift
    Stick Shift
    from LENA IL
    I had a motor that locked up #8 also. I ran the same pistons you ran. Problem was I drove the car down to Carbondale IL and that is where it let go. It made for a bad weekend.
    Looks like you are keepin busy over the winter. Nice work. :)
    Deuces likes this.
  7. Zig Zag Wanderer
    Zig Zag Wanderer
    c'mon Ryan...dish on some pics of that hydro-stick trans you got yer hands on:D
    seriously, looks great so far and it's going to be better than ever.
    Deuces likes this.
  8. Von Hartmann
    Von Hartmann
    thanks man,
    Haha, the pics of the Hydro will come. In fact that little hint of red behind the front clip and eelco tank is it hiding under the pinball machine.
    Deuces likes this.
  9. Undercover Customs
    Undercover Customs
    I hate Holley's. That rod is a show piece...
  10. breeder
    breeder
    you and your pops sure have some cool shit!~
    Deuces likes this.
  11. zimm
    zimm
    from iowa
    did I see you at wild wades sunday?
    best of luck geting it back on the road for vintage torque fest
    Deuces likes this.
  12. superjunkman
    superjunkman
    from Austin, TX
    Nothing cooler than a J.
  13. Von Hartmann
    Von Hartmann
    I don't believe so. I haven't been going to many events. I did got out saturday for a drag expo, but that's it.
    Deuces likes this.
  14. Von Hartmann
    Von Hartmann
    Ha! thanks man. we have some neat pieces, but I still don't hold a candle to Kiwi Kevs collection
    Deuces likes this.
  15. scrape
    scrape
    dang,,, you do got alot of cool stuff..... and id like to see the B&M Hydro Stick ya got...... what shifter you gonna use on it????
    btw how old are you?????? you look pretty young..... lots of talent.....
    Deuces likes this.
  16. Church
    Church
    from South Bay
    Kick ass Ryan. Keep it up. I expect burnout pics sooner than later.
    Deuces likes this.
  17. Hellfish
    Hellfish
    That rod is kind of like "art" now. :)
    I hope both cars make it to the Heads-Up. Too bad you can't race yourself. :D
    Deuces likes this.
  18. scrape
    scrape
    is that a 55chevy steering box???
    Deuces likes this.
  19. holeshot
    holeshot
    from Waxahachie
    VON...It's a good time to drop a 350 in. wouldn't you like 4 bolt main cap's i'am just saying. man in 1964 i jazzed a 327 up to 10,000 r.p.m. i would have killed for 4 bolt main's...POP. it's your FEET! HA!
  20. rusty76
    rusty76
    from Midway NC
    Cool man. Now just take the rod and make a shifter out of it for another project.
  21. Von Hartmann
    Von Hartmann
    Well, I'm missing some parts to the trans. that's why I'm just going to do a test fit to see how it clears the floor. It may be a next winter project.
    I'm missing the flywheel, starter, and yoke.
    I'm going to make the shifter. I've pretty much figured how to make one with substantial detents and neutral and reverse lock outs. I bought an old 3 speed truck shifter from The Warshawsky muffler man shop for $2 that will be perfect to modify.
    I'm 20
  22. jeepster
    jeepster
    from wisconsin
    Ryan, Good to see you making progress on the "J". Best of luck brutha!
  23. dashman
    dashman
    from Viroqua WI
    Von,
    It looks like you got a few things on your plate, give me a buzz when you have time to fly my way. Love the brake lever, can a guy really make anything too light?:D
    Dashman
    Custom Speed and Hot Rod Parts
  24. Von Hartmann
    Von Hartmann
    I'll spit out the info on the front suspension now, cause I have a lot of people ask.
    It's a 38 willys axle, willys springs, willys spindles, 67 volvo disc brakes, 68 mustang close ratio steering box with a 37 chevy pitman arm. And 84 Cadillac shocks.
  25. Von Hartmann
    Von Hartmann
    I probably shouldn't be sharing this...
    I'm not gunna lie, it crossed my mind. Too bad it belongs to my brother and he won't part with it. This is going on the model a in the background. But what the hell, why not see what it looks like.
    That is an all magnesium Mooneyham Blower with a Bowers back plate. Weiand carb adapter and intake.
  26. scrape
    scrape
    "Too bad it belongs to my brother and he won't part with it"
    heck,,, that practiclly means it yours to use,,,, dont it.... haha...
    ive been trying to find a hydro for myself for quite a few years.... the thing that sucks is ive missed a couple for pretty cheep... one was here on the hamb for like $300..... the other was on ebay for less than $100(no bids),,, years ago before people were going crazy for them...(the guy wouldnt ship) i should have drove to oh. and got it...
    ....stupid me....
    btw.... i have some pics of a shifter for a hydro i can post......
  27. Von Hartmann
    Von Hartmann
    Please post it. I'd love to see it.
    I've learned a lot about mine from old hot rod magazines. The most helpful info I have is from the 1961 HOT ROD Annual and also from the HOT ROD Technical Library books, all of which I scored from an old lady on a garage sale fo freee.
  28. el Scotto
    el Scotto
    from Tracy, CA
    That J is a damn cool car!!
  29. scrape
    scrape
    i stole these pics of the hamb....
    are you gonna go to the hamb drags????
  30. violet springs
    violet springs
    I like the stance of your car. Is that a Willys axle under the front?
