Technical Tech: How to make 26-27 roadster hinges
Discussion in 'The Hokey Ass Message Board' started by Inked Monkey, Aug 20, 2016.
  1. Inked Monkey
    Inked Monkey
    I recently picked up a roadster pickup and it was missing half of the hinges. It had the door side but not the cowl. I couldn't stand to pay the crazy money they wanted for a new set so decided to build my own. I'm sure others have done the same but I couldn't find threads on them so figured, What the hay? I have $6 in the supplies and just used common tools.
    You'll need some 5/8 rod and some strap.
  2. Inked Monkey
    Inked Monkey
    Next cut off a section of the rod long enough to make the sections and drill down the middle with a 1/4 drill bit.
  3. Inked Monkey
    Inked Monkey
    Then cut off two sections at 10mm
  4. Inked Monkey
    Inked Monkey
    File these to fit the missing sections of hinge. Make sure they spin freely but don't wobble. WP_20160820_14_33_44_Pro.jpg
    kidcampbell71 likes this.
  5. Inked Monkey
    Inked Monkey
    Then cut a section of plate to fit in the hinge pocket and weld it to the new sections. I put the hinge pin in place in order to keep everything lined up. WP_20160820_15_30_37_Pro.jpg WP_20160820_15_30_51_Pro.jpg
  6. Inked Monkey
    Inked Monkey
    And that's it. Nothing fancy but will do the job just fine. I still need to make the others. You could easily make both halves of the hinge using the same method.
    OFT, Rich B., F&J and 1 other person like this.
  7. Pete
    Pete
    Finally! A hot rod related thread!!!!
    Well done, nice and easy tech.
    F&J and kidcampbell71 like this.
  8. flatout51
    flatout51
  9. chessterd5
    chessterd5
    from u.s.a.
  10. manyolcars
    manyolcars
    Use your lathe so the holes are centered. Isnt the tab supposed to be bent near the round stock?
  11. Inked Monkey
    Inked Monkey
    If I had a lathe I would have and not from the pictures that I've seen. This hinge fits in there and the door closes. If you have a better picture of a hinge, post it up please.
  12. Very good , this is the kind of post I like to find. Thanks for sharing.
  13. F&J
    F&J
    winner..
    what else good stuff you do? LOL
  14. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Very nice!
    I suppose if one was fabricating both hinge halves, he could bolt the plates to the jamb and door, then position/shim the closed door in place. Then position the drilled rod pieces in place with hinge pin/shims and carefully tack weld. Disassemble for final welding and finishing.
  15. Inked Monkey
    Inked Monkey
    I got both sides done and the doors open and close smoothly so I'd mark this down as a success. WP_20160831_14_24_36_Pro.jpg
  16. nunattax
    nunattax
    from IRELAND
    what about a build thread
  17. Inked Monkey
    Inked Monkey
    Ha, It would be such slow progress, I'm afraid everybody would lose interest. I'll still probably start one.
    bengeltiger and bct like this.
