Tech: Exhaust fabrication tips
Discussion in 'The Hokey Ass Message Board' started by SimonSez, Jan 12, 2010.
  1. SimonSez
    SimonSez
    I was making some exhaust pipes the other weekend for Firefly's 34 pickup and thought I would share some of the tricks I have been using to make it go a little faster.
    The first one is to make a carboard pattern that matches the bends that you are using.
    You can then use this as a pattern in the car to decide how much of the bend you need. When it is the right angle, fold the pattern where you want to make the cut.
    Then take the folded pattern and lay it on top of your u-bend and mark it. This also has the advantage that your cuts are square across the radius of the bend.
    Once you have the bend cut and sanded for a perfect fit, the next problem is how to hold it in place while you weld it. I have tried a few different ways, but the easiest and quickest I have found is just to use masking tape!
    Clean any oil off the pipe, and tape the join tightly with masking tape. When you go around a few times, it ends up fairly rigid and the pipes are well aligned.
    Take it over to the vise and cut a short section of masking tape out for a tack weld.
    Then tack it together. The tape gets a bit hot, but still holds together.
    Then flip it over and repeat on the other side of the join. When both sides are tacked, you can remove the tape and clean off the adhesive residue.
    Heres another example, showing how you can use witness marks on the joint to make sure that it didn't move while you were taping it up. In this case, the bend was more complex and I couldn't support the joint in the vise while welding it. The tape was still tight enough to hold the two pieces together to weld together though, and it came out fine.
    Heres the finished pipe, ready to fit.
  2. SniffnPaint
    SniffnPaint
    Cool thanks for sharing.
  3. pasadenahotrod
    pasadenahotrod
    from Texas
    Nice work. Thanks.
  4. harrington
    harrington
    from Indiana
    Great tips, these can all be applied to fabbin'up headers too.
  5. rob lee
    rob lee
    from omaha,ne
    Thanks for the tip!
  6. redlinetoys
    redlinetoys
    from Midwest
    Nice little set of tips using actual experience. Every little bit helps. Thanks for posting!
  7. Wildcat Garage
    Wildcat Garage
    from Marion,NC
    I just finished my exhaust.I wish that I had known about these great tips.Thanks!
  8. fitzee
    fitzee
    Some time the smallest tips are the best. I really like these.Thanks.
  9. I like your masking tape joint, real eazy and real cheap. I have used hose clamps with 3/8" holes drilled in them to tack the joint through. It works OK but the tape Idea might just work better, I'll definitely give it a try on the next set of pipes I build.
    Thanx
    Jaysin
  10. retromotors
    retromotors
    Great tips ... thanks for posting!:D
  11. fiftyv8
    fiftyv8
    from CO & WA
    Great tips thanks.
  12. jonzcustomshop
    jonzcustomshop
    I like it !cheap and easy!
  13. stovbolt
    stovbolt
    very usable tip thanks !!
  14. Mark H
    Mark H
    from Scotland
    Wish I'd seen this before I started building my headers!:D
    Thanks,
    Mark
  15. Cshabang
    Cshabang
    good tips..and ill take it a tad further...make a master set of bend template and photocopy it...Id end up losing mine about 50 times while i was fabbing
  16. budrow
    budrow
    great tip thanks
  17. SimonSez
    SimonSez
    I hear ya - I made a template for a tighter bend as well but lost that before I even started !
    The template is made of cardboard, so probably easier to trace a couple of spares rather than photo-copy them.
  18. THE SPEED ADDICT
    THE SPEED ADDICT
    Nice work!
    Thanks for the tips!
  19. 3onthetree
    3onthetree
    Great job!! Thanks for taking the time to post it. I recently finished fabing the exhaust for my car and truck. The template trick sounds like a good idea, I'll definitely have to keep that in mind for next time.
    I used a hose clamp snugged around the pipe, and traced around it with a sharpie marker to make my cut lines. I've also had good luck by using a few magnetic traingles to help hold the pipes in position for welding.
  20. crs36
    crs36
    from Alberta
    very straight forward, I like it.
  21. langy
    langy
    I do it the same way, I've tried the hoseclip with a hole in it as well but the tape works much better.
    I find the tape leaves glue behind so after tacking i clean the joint.
  22. banzaitoyota
    banzaitoyota
  23. onlychevrolets
    onlychevrolets
    thats how I've been doing it for close to 33 years.....it's not hard, just take your time and make the joints as tight as you can. Some times I get them so tight my old ass eyes can't see them to TIG weld them. If you get them that tight no filler rod is needed you can "fuse" them together, that makes a very tiny bead. I always try for that fit.
  24. Great info! Thanks for taking the time to post and provide photo's. Much appreciated.
  25. 31-5window
    31-5window
    from Michigan
    Great tips thanks for sharing.
  26. Royalshifter
    Royalshifter
    Moderator
    Simple techs are very cool for a small brain like mine.
  27. zman
    zman
    from Garner, NC
    all tech week to the top 11
  28. Correy Smith
    Correy Smith
    Simon, these are some fascinating tips that you provided on doing a custom exhaust fabrication. You know, this is something that I am preparing to do for work. Well, since a client of mine wanted me to do for upcoming week. http://www.genie-exhaust.com.au
