I have a chopped, original steel 1931 coupe. It was done way back in the day, and done correctly. I also have most of what you will need to build a AV8 coupe, the traditional way. I have a 1936 banjo rear end, wide 5 rims, no tires, rear buggy spring. Brand new top wood kit. 3 row chopped radiator and 31' grill shell. Speedway under floor mount brake & clutch pedal, 4" dropped & drilled I-beam front axle and wishbones, front spring & a disc brake kit with wide-5 adapters. Oh yeah and I have original hubcaps. There is so much more that I have for the car it's almost easier listing what you'll need. Included is a freshly rebuilt 51' flathead. I have original nos offenhauser heads, Fenton dual carb intake & carbs, not installed . 1936 trans with 39' gears. Vintage headlights, tail lights. Most the parts are real vintage parts, not new aftermarket crap. I have more. I've been collecting parts for 4 years to build a traditional AV-8 coupe.
