my shifter is sparking... really.
Discussion in 'The Hokey Ass Message Board' started by Gromit, Apr 17, 2012.
  1. Gromit
    Gromit
    Working on the '56 chev today, which is running poorly (Carbed 350/700r4 combo) I noticed when hitting the starter the shifter was sparking on the floor pan.
    I'm thinking a poor ground, but anyone else have an idea?
    Never seen anything like it:confused:
  2. Gromit
    Gromit
    BTW I checked and re-checked the wiring, it's where it should be. (EZ wiring kit)
  3. Soviet
    Soviet
    Ground the block.
  4. Bruce Lancaster
    Bruce Lancaster
    Ditto. GM once saved money by skimpy block grounding...and got a rash of guarantee failures involving things like melted trans kickdown cables as electricity hunted around for grounds.
    As a minumum, get a ground cable run from a bolt on engine straight to wherever bat cable bolts to body
  5. squirrel
    ground the block to the frame and to the body. Best is to connect the negative battery cable directly to the block, not to the frame or body (but you still need smaller ground straps connecting the frame and body to the engine)
  6. Gromit
    Gromit
    Thanks guys. I suspected as much after posting I checked the ground.. only one.. tothe chassis.
