Hot Rods My 32 roadster project
Discussion in 'The Hokey Ass Message Board' started by Hutch built, May 15, 2016.
  1. hasty
    hasty
    Stunning workmanship
  2. AmishMike
    AmishMike
    I do remember removing that early metal shielding to get at the plugs - then finding the radio was messed up. Have not seen in a long time & never on open engine. Thanks for reply.
  3. Your work is absolutely amazing and I am deeply impressed by the level of workmanship. With your roadster project you are teaching more than any metalworking course or how-to-video I watched on the web.
    May I ask what your background is? Thanks, Ralf
  4. Hutch built
    Hutch built
    I've worked for the local utility company for about 34 years now and when I was in my early 20's I was at one of the power plants. While there I was amazed at the skills of the machinist and welders and learned all I could from them. After that I just started buying equipment and started teaching myself how to use them.
    Sent from my SPH-L720T using H.A.M.B. mobile app
    bct, Baron, Bulletnose26 and 2 others like this.
  5. Thanks John. Nothing beats experience ;) Probably the best advice to watch, listen and practise, practise, practise, ...
  6. Hutch built
    Hutch built
    I fabricated the exhaust while the floor was was removed so I could work from above. I used 2.5 tubing U bends, chambered mufflers, and some flanges made on the lathe. In the rear section I went up and over the rear spring cross member because the trunk flood was going to be raised so it would be flat. Then I made a rear pan that the exhust tips come through and had it louvered.[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  7. Hutch built
    Hutch built
    Here's a quick overview of the floor and firewall installation. First I made some panels to raise the trunk floor so it would be flat. [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG] Made a poster board pattern and then bent up and bead rolled the trunk floor and welded it in place. The rest of the pictures are of the main floor, Trans tunnel, and firewall. [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  8. bengeltiger
    bengeltiger
    Very nice work. People keep mentioning "Riddler" on your thread for a reason.
  9. Perfect. This project would make an excellent How-To-Build-A-Hot-Rod book showing outstanding workmanship and lots of photos that tell more than endless pages of text. Respect
  10. Black Panther
    Black Panther
    from SoCal
    Dude. This is some Doane Spencer level work and execution. Very impressed...will keep this thread and your pics for future inspiration...
  11. Pewsplace
    Pewsplace
    The work is very impressive, but the presentation photos are right up there with the best. Nice work on both issues.
    lothiandon1940 likes this.
  12. DDDenny
    Lynn, you nailed it, those photos are what keep us coming back, this build is just so well executed and tasteful.
    Kudos Hutch
    Baron likes this.
  13. AmishMike
    AmishMike
    Hoping to see your car at York but did not make it today with all the rain - maybe Saturday but have to reschedule things. Wondering why the rear sway bar - have not seen that done before. I know what it is for but does a light rod need one? You going to auto-cross? Have you driven with & without for comparison??? that would tell the tale. tks - great build & pics.
  14. Hutch built
    Hutch built
    I'm at York this weekend but the roadster isn't, still building it, maybe next year. The sway bar is a 40 front sway bar off a truck. I had a rear sway bar on my coupe and it really helps with keeping the body roll to minimum which is good if the tires are close to the body.
    kidcampbell71 and lothiandon1940 like this.
  15. spags
    spags
    I can't get over the craftsmanship in this build! Love following your build
  16. Hutch built
    Hutch built
    Here's some shots of the engine mount going together. [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  17. Shit batman....This is out of this world.....Sure am glade I never seen this when I was building my 3 window as I would have pitched everything and started over........Thought and quality of work is above anything I could have dreamed of......I see nothing I don't like.....I am with everyone as you need to put this build out there for everyone to enjoy....
    3 window Larry where in the hell are you at on this one?????
  18. hammered30
    hammered30
    from west aus
    Man there's some sweet work happening here. Thaks for posting
    cheers Paul
  19. KoolKat-57
    KoolKat-57
    from Dublin, OH
  20. Amazing work. I like the idea of repeating the three-hole-design here and there. Though I am still impressed by every new photo.
  21. Hutch built
    Hutch built
    Not sure what happened here but after fitting the windshield post to the body, which requires shaping the brass stanchions, the bottom of the windshield overlapped the post. To correct this I removed the glass from the frame and cut about a quarter inch out of the lower part and welded back together and then had the glass sanded on the sides to fit. In the end it all looked great. In no way am I dissing the Rodwear set up, it's a nice piece, it could have been I fitted it wrong when shaping the lower stanchions. [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  22. 3wLarry
    3wLarry
    from Owasso, Ok
    I've been here all along Dennis...blown away like everyone else
  23. GREAT! As I was starting to worry about ya........
    3wLarry likes this.
  24. Hutch built
    Hutch built
    This series of shots show how the hood was fitted. I was lucky that I only had to remove material where it was overhanging and not add any. I would sand the edge of the hood where it was folded over and peel off the inner strip the sand/file the edge for a good fit then weld the inner strip back on and sand the weld smooth. The corner had to be removed and a small section removed then reattached to keep the revel on the corner.[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  25. You missed your calling. You should have been a surgeon.:)
    kidcampbell71 and Cyclone_racer like this.
  26. Ol Deuce
    Ol Deuce
    from Mt. U.S.A.
    WoW What a Great Build Top Notch Job!!! ;) Ol Deuce
  27. Pat
    Pat
    from Felton Ca.
    Beautiful craftsmanship!! And you could eat off the shop floor!!
    tfeverfred likes this.
  28. Fantastic job, all wrapped up in the perfect package!!:cool::cool::cool: Now I think I'll go to the shop and crush my project.
    lothiandon1940 and DeLuxe 32 like this.
  29. tfeverfred
    tfeverfred
    Oh......My.........Gawd........
    Bookmarked
  30. tfeverfred
    tfeverfred
    I want to BE the shop floor.
