Hot Rods Model A Axle Hydraulic Juice Brakes-Spindles-HELP
Discussion in 'The Hokey Ass Message Board' started by bab59, Jun 19, 2012.
  1. bab59
    bab59
    Got several model a axles laying around.
    What spindles and hydraulic brakes assemblies do I need to put one of these under the front of a hot rod?
    Spindles--Years--Makes---Models
    Brakes Also
    Dont care about bolt pattern as long as 5 bolt.
    What works best... what should a guy stay away from.
    Thanks in advance.
    If anyone has any parts for sale that will work PM Me.
  2. 48-52 ford F1 truck pins right on.
  3. TERPU
    TERPU
    Model A Axle will take '39-'48 spindles backing plates and drums. Also F-1 48-52. These are the most often used. F-100 stuff can also be made to fit and '54 Chevy style stuff. You can also use model A spindles with adapters for juice brakes.
    Good Luck,
    Tim
  4. bab59
    bab59
    Will the 49-53 f1 spindles work on the model a axle? What's different about the spindles pre 48?
  5. manyolcars
    manyolcars
    On the front of my Model A, I have, A axle, A spindles, 39 Lincoln backing plates, 2" 1976 Chevy shoes and self adjusting parts, 1964 F250 wheel cylinders and 1940 drums with 1935 Ford wire wheels and steelbelted radial tires that were made for the electric RAV4
  6. bab59
    bab59
    Just purchased a 49 f1 complete with the 8ba
    Any difference in these spindles or will they work fine?
    What all should I rob off of it for a model A rod build
