Technical Locktite ?
Discussion in 'The Hokey Ass Message Board' started by dtwbcs, Feb 24, 2017.
  1. dtwbcs
    dtwbcs
    from Brenham,TX
    Was checking my intake&exhaust-235 with dual C/W's
    Was wondering if I could use blue locktite on the bolts? Some were loose.I have a pretty rumpy cam(3/4) and it does vibrate the engine at times.
    Thoughts-
  2. squirrel
    sure....it should help.
    tfeverfred and dtwbcs like this.
  3. dtwbcs
    dtwbcs
    from Brenham,TX
    That's good to know. I might put some on other bolts that I find loose.
    Thanks
  4. it always seams to take 3 "tightenings" before they stop coming loose. at least that is what i have found.
    dtwbcs likes this.
  5. DDDenny
    dtwbcs likes this.
  6. squirrel
    I agree with the three tightenings thing. I'd give it some time before trying loctite. Once the gaskets compress fully, then add locktite.
    1927graham likes this.
  7. dtwbcs
    dtwbcs
    from Brenham,TX
    Its been in the car several years now. Was referring to the the "bluetite" claims loosens with hand tools....
  8. To loosen red locktite, you put heat on it. Don't know if its suitable for headers. Blue can be loosened with tools.
    dtwbcs likes this.
  9. Joliet Jake
    Joliet Jake
    from Jax, FL
    Red works for me down to 1/4" fasteners but for exhaust, grade 8 lock washers, in my experience, locktite will "burn" over time.
  10. You could look at it simply,
    Blue could be used on external fasteners that could vibrate loose,
    Red for internal fasteners that you don't want floating around your rotating parts.
    This is how we think putting hydraulic components together.
    Get a Loctite spec sheet,there's many varieties and purposes.
  11. gimpyshotrods
    gimpyshotrods
    If you mean split-lock washers, no. They work no better than a plain washer, or no washer at-all.
    If your bolts are not loosening, it is because you torqued them properly.
  12. Torana68
    Torana68
    from Australia
    Loctite is good when used properly and its best to use the number rather than the colour, they don't make a Loctite that will survive exhaust temps . 290 is a handy one for applying without pulling things apart (if still clean)
  13. dtwbcs
    dtwbcs
    from Brenham,TX
    if still clean-good point
  14. deathrowdave
    deathrowdave
    from NKy
    Studs with nuts would be a great help if you have room to install . You can add larger amounts of torque . Loosening up is wearing on threads in head where bolts are screwed into . Studs would prevent this also , thread lock or locknuts on outside stud thread will work better than threadlocker on internal thread
  15. indyjps
    indyjps
    You could try new high quality bolts. If you reused the old ones they they probably have worn threads from multiple tightening and corrosion.
    I do like loctite.
  16. tikiwagon13
    tikiwagon13
    Loctite won't work for headers, too hot. Check the bolt length, make sure they are not bottoming out before the proper torque, seen it happen. Just to be safe I would buy ARP header bolts made for your application, follow their toque specs and you'll be good to go.
    dtwbcs likes this.
  17. mcmopar
    mcmopar
    from Strum, wi
    Green Loctite will make sure that it wont come loose.
  18. jimmy six
    jimmy six
    The "correct" lock washers for headers look different. They are thicker and not necessarily larger in diameter because of the tight fit. Not on headers but my personal Loctite is machine screw purple.
    dtwbcs likes this.
