Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. banjeaux bob
    banjeaux bob
    from alaska
    Bob,it's amazing how this stuff travels around...
  2. onelung
    onelung
    from Adelaide
    A Dekko at the Decauville
    Known as Decauville's Voiturelle, this was a hot sell in 1898 Paris. It cost £140, one third up front and the rest on delivery.
    At the steeplechase of Auteuil a very pretty little motor-car made its first appearance and was greatly admired. Light, very elegant, painted in bright golden yellow, with two comfortable seats. This motor-car merits considerable attention, as it is very easy to manipulate, and can be turned in a small space. Later on, at the Paris Agricultural Show, it was one of the greatest attractions of the Exhibit of the Société Decauville.
    Full particulars of the car may be obtained at the offices of The Société Decauville :— 13 Boulevard Malesherbes, Paris.
    Well, good luck if that adress produces a result now ... ;)
  3. onelung
    onelung
    from Adelaide
    Same engine - does it still look like a V4?
    Mors made V4's, but to my knowledge, not Hotchkiss.
    And I venture to suggest that it is a very long way removed from a cyclecar.
  4. UKAde
    UKAde
    from Oxford UK
  5. onelung
    onelung
    from Adelaide
    Yes - that engine IS a V-4. But not the other from post #3474.
    So ... we've been talking about two different engines?
  6. Airhead Roadster
    Airhead Roadster
  7. banjeaux bob
    banjeaux bob
    from alaska
    Shelsley Walsh! Great find Airhead Roadster.
  8. Ned Ludd
    Ned Ludd
    The narrow angle suggests Lancia, but as far as I know all the narrow-angle Lancia V4s had a single cylinder head, like this Lambda:
    Profuse apologies for introducing a third V4 :D
  9. onelung
    onelung
    from Adelaide
    Not at all: in fact this last makes only the second V 4. Maybe we can move on before it becomes even more confused?
    Post #3439... the aero engined Amilcar.
    It IS aero engined, but not quite as one normally thinks of as an aero engine.
    A Globe-Dayton fitted into an Amilcar CGSS
    3 liter: based on a Ford A bottom end with air cooled barrels (maybe it's only used during a typical UK winter?).
    Here's the story about the Globe-Dayton from this website.
    http://www.memaerobilia.com/engineselection.asp
    Story is that only two of these engines survive.
  10. banjeaux bob
    banjeaux bob
    from alaska
    Here's a picture of a guy named Bourbeau with his Bedelia in 1913 at Le Mans.It appears that the source of the photo is the National Library of France.
  11. onelung
    onelung
    from Adelaide
  12. banjeaux bob
    banjeaux bob
    from alaska
    Looks like Prescott.
  13. onelung
    onelung
    from Adelaide
    Not Prescott this time, rather - Musée des Arts et Métiers, Paris - 2007.
  14. banjeaux bob
    banjeaux bob
    from alaska
    1927 Morgan Super Aero. Vincent-Vintage Reivial Montlhery pic
  15. a-c-h-i-l-l-e
    a-c-h-i-l-l-e
    from France
    This car is still in Paris museum, very nice patina.
  16. banjeaux bob
    banjeaux bob
    from alaska
    Very nice Lung and ACHILLE! Thank you.I love the building as well as the Aerocar.Tile work and stained glass..just fabulous. Was this building always used for this purpose?
    BanjeauX Bob
  17. UKAde
    UKAde
    from Oxford UK
    The new owner of the chater lea come over to pick it up , I was a little sad but I have to get the jappic done,
    They were both very interested in seeing the jappic in the flesh , and now I have more space in the garage
  18. banjeaux bob
    banjeaux bob
    from alaska
    I can't remember if I have posted this 1914 Majola from Vintage Revival Montlhery or not...
  19. onelung
    onelung
    from Adelaide
    Musée des Arts et Métiers. Paris. Go there via the Metro as the station is done in Steampunk décor - wonderful.
    The building was a church/cathedral, now added on to in modern style. Allow yourself a full day to "do" the museum: it's full of wonderful things.
    As just one example, Cugnot's "Fardier" from 1770.
  20. banjeaux bob
    banjeaux bob
    from alaska
    Danke,Merci,paldies,THANK YOU...once more Lung!
  21. a-c-h-i-l-l-e
    a-c-h-i-l-l-e
    from France
    I agree, the museum is very pretty and interesting. In a superb building.
    One more, the Hélica is on the left.
  22. UKAde
    UKAde
    from Oxford UK
  23. onelung
    onelung
    from Adelaide
  24. Airhead Roadster
    Airhead Roadster
    Played around with body lines the other day though I'm still a very long way away from that stage. For a while now I've been stuck on driveshaft design, but I think I finally have it sorted. Thought I would take and share a few pics. Happy Holidays!
  25. UKAde
    UKAde
    from Oxford UK
    Great stuff,, interesting oval looks very 50's racing car, personaly i would go for the early gn look have a very narrow front body and have the cylinder heads and part of the barrels exposed out of the sides of the body, ,
    early gn s just had a pointed nose then later had a faux radiator grill to apppear more modern
    you could go veteran and have a cylindrical copper fuel tank with a point on the front obove the engine, this would mean you dont need a fuel pump
    this certainly has the makings to be a great car ,
  26. chuxx
    chuxx
    Looking good AR! I agree with Ade on the exposed jugs. Do you plan on having a reverse gear? What about the Jappic, Ade, will it have a reverse?
  27. kennyrayandersen
    kennyrayandersen
    from TX, USA
    the 1/2 VW keeps 2 opposing cylinders whereas the FIAT 500 are not only on the same side of the engine, but the cylinders fire together. Unfortunately the 1/2 VW conversion chucks the flywheel end and mounts the prop on the opposite end, the prop then acting as the 'flywheel' if memory serves me well (all bets are off). I always thought that the 1/2 VW would make a good conversion for a FIAT 500 if you could figure out how to retain the flywheel.
    In reality, they are getting rare, and even a dilapidated one will fetch $3K! I have a restored 1963 500 D plus a spare motor/tranny, but they are a host of better engines to use (IMO) for a cyclecar.
  28. Flat Ernie
    Flat Ernie
    Tech Editor
    GM's Lean Machine of the early '80s or so used a half VW and must've had a flywheel.
    I think you're correct, the aero-conversions of the half-VW use the prop as a flywheel, but that doesn't mean you can't bolt the flywheel on the back and cut it off at the other end/half. ;)
  29. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    They probably cut the back half off so they don't loose the oil pump.
  30. ebtm3
    ebtm3
    And the timing gears.
    Don't think--from what I remember of the ones that I had that the air cooled Fiat 500 had both cylinders fire together. Would make no sense. Of course, the whole damn car made no sense.
    Herb
