Joe's Speed Shop - Axle Dropping
Discussion in 'The H.A.M.B. O'Dex' started by Old Racer, Oct 22, 2013.
  1. Old Racer
    Old Racer
    We've been dropping, drilling, and filling 1928-36 Ford axles for over ten years now... We also do king pins, tie rods, and all kind of other custom work. Here are some examples:
    Axle A is a 28-31 Model A Ford which has been stretch dropped 4 inches.
    Axle B is a 32 Ford Heavy which has been stretch dropped 5 inches.
    Axle C is a 32-36 Ford which has been stretch dropped 4 inches.
    We can provide you with a dropped axle or we can drop your axle. Retail price to drop an axle is $200. Core charge for Model A is $50.00 and for 33-36 axles is $75. Core charge for a 32 Heavy is market value, presently around $400.00 (when available).
    All axles are straightened if necessary, kingpin bores are resized if needed, and all axles are Magnafluxed before shipping. We also can fill the ends of the axle for $100 and drill the center for $100. You have a choice of stretch drop or conventional drop. The difference is stretch drop maintains the original width within 1/8 of an inch, while a conventional drop shortens the axle approximately 3/4 of an inch per side.
    Oh, and if you have a 37-41 axle that needs dropped hit up our pal Sid at Nostalgia Sid's. He will treat you right.
    Otherwise, drop us an email, send us a pm or give us a call. We'd be glad to help.
    More details here - www.joesspeedshop.com
  2. Ryan
    Ryan
    ADMINISTRATOR
  3. FLAT-TOP BOB
    FLAT-TOP BOB
    HAMB O'dex Editor
    Joe is one of the best.
    Only guy that does my early ford axles
  4. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Joe did my 32 Heavy with outstanding results!
    Excellent workmanship and a true professional!
    Highly recommend!
  5. GOATROPER02
    GOATROPER02
    from OHIO
    Joe's axles are Ross Racing Engines approved!!!!!
  6. Lukydevl
    Lukydevl
    from Arizona
    Joe dropped and drilled my 32 Heavy, and bent my steering arms.. Very nice job!!
  7. mastergun1980
    mastergun1980
    from Alva OK
    Joes does awesome work!
  8. 32rustedinpiece
    32rustedinpiece
    Just got 4 axels back from joe and very satisfied with the results. Very good communication, and got them back when he said i would. On time and reasonably priced. Highly recommended. Thanks .
  9. Kevin Lee
    Kevin Lee
    Super Moderator
    No before photos, but this axle is "old chrome" and had a hell of a bow between the perch pins. (Laying flat on it's side I measured about an inch and a half of space in the middle) Joe assured me he could "gently coax" it back without harming the finish.
    I was so impressed I bought a dropped A from him just to have on hand for future use.
  10. oj
    oj
    He's done a few for me, excellant work.
  11. bondolero
    bondolero
    Got Bendix brakes and original hubs as well as dropped axle. Very helpful in my build.
    thank you
    Larry
  12. 345
    345
    from Michigan
    Highly recommended - service and
    quality is first class!
  13. Wildfire
    Wildfire
    Good guy. Did the drop on my Model A axle some years back. Very happy with the price and speed.
  14. mcbay
    mcbay
    Joe did a 1" Gentlemans drop on my 32 and set it up for Lincoln spindles......and took out a kink to boot....It is right on. ;)
  15. 21stud
    21stud
    Double and triple that. He worked on a 32 Diego drop for me . Great job and service. !!
