This will save you a ton of time, Styled after the old Hurst engine mounts. Designed to place the trans mount level with the bottom of the frame. Relief cuts make it a synch to bend up and then allows full penetration welds. Can be used with inset boxing plates or trimmed to use with flush welded boxing plates. Will work with most non-Z'd pre-war frames (shown in a 32 frame) U-weld kit; All materials shipped flat you will need to form the lower flange, and weld together. $49 plus $12 shipping Fully welded mount and frame brackets $149 Plus $20 shipping Alliance members get a 10% discount as always! Robert 208-816-2297
