Technical How To Remove RUST Stains On Whitewall Tires?????
Discussion in 'The Hokey Ass Message Board' started by CarQuestions, Jun 20, 2015.
  1. CarQuestions
    CarQuestions
    !!!Grrrrr!!!
    I just did a VERY BAD thing...I used Aircraft Paint Stripper and striped the paint off of some rims that had tires mounted...then I sanded down the rusty areas and sprayed on some OSPHO. Later I came out to find that the wide whitewalls are brown with rust stains. They were super clean prior to the sanding/OSPHO process.
    Ive tried Bleachie-White, Comet, muratic acid, and every combination of bad word I can think of and no use...the brown stains stay there and are not even touched. I am off to try some CLR.
    Has anyone solved this rusty whitewall problem????
    Note to self: Never...ever...EVER try to prep/paint rims with tires still mounted on them...it is a COMPLETE WASTE Rusty Tires.jpg of time/money.
    Model T1 likes this.
  2. Gman0046
    Gman0046
    I'd paint em black. That stuffs not coming off
    Gary
  3. Hotrodmyk
    Hotrodmyk
    1. Northwest HAMBers
    Don't really know but I have a small brass wire brush made for whitewalls that takes off some pretty nasty marks. Maybe???
  4. AndersF
    AndersF
    Just buff it off with sandpaper and seal the white with Armour all or something similar.
  5. pitman
    pitman
    On fabric, lemon juice takes rust out...
  6. This has been the mainstay for whitewall cleaners all my life, it is still marketed this way and is also called black majic by the same company. if anything will make them white again this stuff will.
  7. unkledaddy
    unkledaddy
    When I was a kid and used to build model cars I would paint their black walls with white wall tire paint.
    It came in a one-pint can at Western Auto. I don't think they make it nowadays. But, there
    was a guy in Norway I think that marketed a WW tire paint, come to think of it.
    I was mistaken, there are some vendors. Here's one; http://www.rangerpaint.com/
    Scrape a rust spot with a razor blade to see how deep the stains go. Then you'll know if you want to try buffing them out or not.
  8. jcmarz
    jcmarz
    from Chino, Ca
    or white, or just leave it and call it patina!
  9. Sandpaper is good. The white goes to the cord. Alos, try some CLR.
  10. todd burgess
    todd burgess
    Go to the grocery store and get whink it is meant to take rust out I use it in my sink and have had white rubber mats in my sink that have had rust spots And it takes it right out works on fabrick and even paint. Your not out much and scrubbing won't take it out.
  11. If they're iron-based rust stains, then oxalic acid (Naval jelly) will remove them.
  12. 41 C28
    41 C28
    Maybe try some vinegar.
  13. Gman0046
    Gman0046
    Fresh dog urine will do the job. Just make sure its fresh.
    blackout likes this.
  14. Galaxie390
    Galaxie390
    I've worked in a tire store for 35 years. The white rubber is thick enough to endure some careful buffing to expose some clean white rubber. I've used a rasp wheel on a die grinder. Be gentle
  15. joeyesmen
    joeyesmen
    I have always had pretty good luck with SOS pads and water.
  16. Nothing to lose at this point so try everything/anything: paint remover/lacquer thinner/mean green/lemon juice concentrate (I know it removes rust) etc.
  17. CarQuestions
    CarQuestions
    OK...THANKS for the input.
    I tried the following with ZERO success:
    Mariatic Acid
    CLR
    Molassa (soaked over night)
    Bleachie-White
    Scrubbing with SOS pad
    I am now soaking the whitewalls in Naval Jelly under a layer of cling wrap over night.
    Scrubbing with and SOS pad and Bleachie White had very minimal effect...but helped some.
    I'll let you know the results...
  18. That's not rust, it's staining. The phosphoric acid stained the white walls. I think you'll need to sand them to get it off.
  19. PontiacPower67
    PontiacPower67
    Ok here's what I've done with success on different occasions:
    CLR with a soft scotch brite pad... Comet powder mixed with a little water to make a paste also applied with a scotch brite pad, then reapply and let it sit 'till it dries and scrub off.
    If all else fails use white shoe polish, it may not last forever but looks good for a while.
    Good luck !!!
  20. Model T1
    Model T1
    As mentioned many people have turned blackwall tires into white walls by gently grinding them down.
    So to make white wall tires white again I suggest you gently sand them down after trying everything else.
    I've used Bleche White or SOS with Comet for years!
  21. dan c
    dan c
  22. RICK R 44
    RICK R 44
    try Castrol Super Clean. Spray it on and scrub with a grey scotch brite pad, rinse with warm water. Most white wall manufacturers do not reccomend cleaning products that contain bleach
