Hello from ACME30
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by acme30, Feb 4, 2012.
  1. acme30
    acme30
    from Australia
    Hi all
    I am a long time lurker from Western Australia but finally have bitten the bullet and joined the HAMB
    I have a home built model A coupe I first got licensed in 2000, I have about 60,000 miles on it and we have driven it a number of times from the west coast to the east coast of Australia and back. It is all pretty standard for where I live 289 windsor, C4 and 9 inch rear.
    My long term project is a 1932 ford closed cab pickup. It has 8BA flatty, 4" crank and a 453 GM supercharger. Top loader 4 speed with jeep shifter.
    Cheers ACME
  2. Welcome from Minnesota,--I like your 32 pickup plan, but the 5 window Model A is still my favorite.
  3. Greetings from Iowa!
  4. Sir Woosh
    Sir Woosh
    Welcome aboard from way over on the other side!
    I really admire the rodder (like you) who builds and drives as many miles as possible...........
    Great therapy, isn't it?
  5. 60 ford
    60 ford
    Welcome from Indiana.
  6. Cruizin TV
    Cruizin TV
    from Australia
    G'day Jeff, just signed up myself the other day, still finding my way around.
    Murray from the other side of Oz.
  7. styleline
    styleline
    from so-hol
  8. acme30
    acme30
    from Australia
    Hi all
    Thanks for the welcome.
    Sir Woosh - driving miles is all good until something breaks. We have had a few dramas in our travels but having said that we always (with help) were able to fix what was wrong and continue on our journey so all has been good.
    We have met some great people through breaking down.
    Hey Murray those Aussies are everywhere now and getting into everything:0
  9. farmer12
    farmer12
    Welcome from the Netherlands and enjoy this great forum!
  10. HotRodderDaughter
    HotRodderDaughter
    from San Diego
    Welcome from San Diego! :)
  11. Cruizin TV
    Cruizin TV
    from Australia
    What Jeff's talking about is his hard luck awards from driving cross country to the nationals, not once but twice. Pretty sure Jeff is the only guy to have collected the award twice but when you drive over 3000 miles just to get there I suppose the odds are increased. One well travelled hot rod, pretty sure it's been driven to and around all states of Australia, except Tasmania of course, had to go over on the boat but driven all over it.
  12. clarthepio
    clarthepio
    Hey ACME,
    Your flatty sounds pretty awesome! How about a few photos?
  13. tommyd
    tommyd
    from South Indy
    Welcome from Indy...yes! FORD IN FORD!
  14. SaltCoupe
    SaltCoupe
    from Indiana
    Welcome to the H.A.M.B.
  15. acme30
    acme30
    from Australia
    Here are some pics of mine from the flathead engine thread on here.
    I wanted mechanical accelerator linkages............... yes I know cable is easlier but I want what I want so 3 days latter :oops:
    And here is a motor shot from the other side
    Engine is an 8BA flathead with a merc 4 inch crank - almost ready to go together for the final time. Need to run some oil lines and check valve to head clearance then that should be it :)
    Blower is a GM453, manifold is a 2 carb Luberg (Australian) machined flat with a custom plate to the blower - BDS blow off valve fitted to front of adaptor and pressure relief valve fitted to snout. Carb adaptors - custom machined as is the rear cover plate. Carbs are blower referenced 94's
    Blower snout is a modified M90 from a V6 Commadore. Oiling of blower is via main oil feed from block (oil feed and return lines not run yet - oil goes in the side of the blower and drains back to block via internal lines in adaptor plate -then back into block in front of oil breather).
    Custom pullies - tension on belt is via alternator - hoping to get away with 1 v belt but if it slips will chnge to 2 belts.
    Have a good mate who did all the machine work
  16. Westco48
    Westco48
    Nice!!!...now lets see the whole car...oh and welcome from socal
  17. clarthepio
    clarthepio
    Sweeet!!!! Looks fantastic!!
  18. Lil32
    Lil32
    Welcome from Lil32 45000 miles on my coupe regards
  19. G,day and welcome from Gippsland.......
  20. acme30
    acme30
    from Australia
    It has been a long time since any work was done on the pickup BUT......................
    Looks like I might be changing jobs so hopefully I can get back into it :D :D .
    Here are the latest pics -
  21. crankster
    crankster
    from down under
    Bloody Hell, Jeff's on here at last.
    Atwater Mike likes this.
  22. acme30
    acme30
    from Australia
    Yeh I am a bit slow to catch on :eek:
  23. Welcome to the H.A.M.B that's some good looking rides you have there
  24. moefuzz
    moefuzz
    Welcome to the HAMB.
    That is a pretty cool little truck, nice to see a Ford in a Ford.
    Keep up the good work,
    moe
  25. clarthepio
    clarthepio
    Your shed is as tidy as your jalopy's !! I wish that was my shed!
  26. Welcome to the H.A.M.B.
  27. acme30
    acme30
    from Australia
    Sorry for posting in the introduction section but I didn't want to start a build post as this is a very long term project but pics were requested in another post so I thought it might be best to put them here
    Here is my buddy Charlie making final adjustments
    We got it started (but can't upload video) on the first go so and it sounded really strong with the merc crank and the 400jr cam so after some adjustments and some drama with one of the brand new Offy heads it was time to work on these but final assembly of the blower took a little bit longer as there were no seals for it in WA and they had to come ex east :evil:
    Pinched an idea of a hidden pcv valve from the HAMB to do this - using a Toyota tarago PCV valve fitted into a core plug which is then fitted into what was previously the downdraft tube then hooked it up with flexible high temp line under the manifold so you won't see it. 8)
  28. acme30
    acme30
    from Australia
    Ok we might have a couple of short video with the engine running - click on the pic (sorry don't know any other way to do this)
    Pre supercharger :cool:
    And with the blower :D Click on the picture for the video and sound
