Projects Flat FED build
Discussion in 'Traditional Hot Rods' started by roseville carl, Jan 14, 2010.
  1. 64 DODGE 440
    64 DODGE 440
    from so cal
    Thought that might get the gears turning. :cool:
  2. Katuna
    Katuna
    from Clovis,Ca.
    I'd be down for one!
  3. fenderless
    fenderless
    from Norway
    Looking good Carl:) Have you plans to brace the ena of the plate, (four coners)? We didn't at first, but found out that the plate was bent when tightning the blower.
    /K
    Taildragger&fenderless
  4. Yea Kjell I've thought of adding gussets to it but haven't done it yet...........
  5. Playin in da backyard again.......
    [​IMG] [​IMG]
    Now to just put the finisging touches on em.....................
    fenderless likes this.
  6. fenderless
    fenderless
    from Norway
    Cool Carl:) Roger is also in the prosess of making a foundry:)
    Oh! Just as you know, several pages from Eagle Field in the last issue of Gasoline Magasine, and you are there too:)
  7. didn't know that Kjell....... hafta see if I can find the mag.........
  8. back to basics............
    mctim64 likes this.
  9. fenderless
    fenderless
    from Norway
    Hello Carl:) Sorry for the late replay. The issue is number 1. 2015. I'll see if i could scan the Picture:)
    /K
  10. Moto Moto
    Moto Moto
    from Krum, TX
    Best thread on the HAMB! Thanks for sharing.
  11. Model A Mark
    Model A Mark
    from dallas
    1. Holley 94 Group
    what book you got laid out there carl ?
  12. Street supercharging by pat Ganhal
    also have the cd by Deans Blowers
    plus assorted other shit.........
    thanx Moto
  13. wrenchbender
    wrenchbender
    Carl that book is a real good reference for what you are doing
  14. Model A Mark
    Model A Mark
    from dallas
    1. Holley 94 Group
    Thanks Carl, Ill look for that book on Amazon.
    Does it have any information on "V" units ?
  15. Not much on the V series just a mention of them but a great book to have in your library
    Yea Randy have had the book since I built the ICT in 2000 the pages are now turning yellow.......... cost 12.95 then.
  16. Bumps n Bruises strikes again..........
    Made jig to drill pin holes to pin rotors...... driving pins in, hit fingers with hammer, say bad words.....piss off neighbors.
    add c clip to drive assy drill hole in end of shaft to attach drive spline.........
    Stock drive shaft that will be cut and welded n pinned to above drive assy............ after machine work drive assy will be case hardened
  17. CGkidd
    CGkidd
    Very cool work there Carl.
  18. Thanks Eric you pull the plug yet?
  19. wrenchbender
    wrenchbender
    Looking good carl
  20. CGkidd
    CGkidd
    I am underway on my way home from Antarctica right now. I start my retirement leave 15 April and my retirement from active duty is 01Sep15.
  21. Gotta make it to Eagle on May 15 :D:D:D
  22. CGkidd
    CGkidd
    trying to figure out budgeting to see if I can. Looks like it will be fun. The drive from Seattle will be killer though.
  23. well Eric you always have a place to stay on your way......
  24. Makin progress slow but sure...........
    decided to use this first since I don't have all the injection parts yet
    a little rebuild is in order
    and of course a new carb base....... to be cast later this week
    [​IMG] [​IMG]
    should look sompin like dis ........
    Of course I don't want to say just how many times I had these rotors in
    and out of the case but suffice it to say I need wing nuts on the case...........
    just another day in the life of a Flatheadder............
  25. wrenchbender
    wrenchbender
    Looking good carl
  26. fenderless
    fenderless
    from Norway
    Looking good as allways in the B&B garage:) Hmm the in and out With the rotors sounded familiar;) I think i can take the blower appart and together blainfolded;) Just an advice, if you haven't done it, be sure to plug the hole in the casing from the front bearing plate. Othervise it could cause some oil leak.
    What parts do you need for the injection set-up?
    /K
  27. Toymaker
    Toymaker
    from Fresno,CA
    Becoming quite the pattern maker my friend.
  28. Na Roc just a cheap ol fart who loves to futz with things........
    Kjell still need to order the nozzles and a new throttle shaft since mine is not straight and binds in the casting plus linkage lots of work to do there yet....... all in due time.....
  29. Well a few more hrs on it.......
    Drive shaft pinned and welded to be hardened this week......
    Sight glass and vent installed..........
    All but the drive assembled for final time.................
    First coupla coats varnish on carb adapter mold........
    [​IMG] enough for one day
