this is my Flake-Eze dry flake gun for only 85.00 and its better then any other on the market as it will spray any size flake all the way up to globel that's used on bass boats here are some samples the gun come's with directions shipping is $10.00 gun come's with directions shipping is $10.00 how to use..... Flakes are sprayed dry from the gun so no messy clean up No more wasting materials and clear build up during flake can spray flake that is from small to bass boat style spray color of car as normal with your base color then use your clearcoat and spray one area just enough to get it wet then then hold flakegun about 12 inches away and with desire pressure from 20 to 35 pounds ( for flake amount thin to thick ) spray the flake on the clear then apply a light coat of clear to area then move to the next area If you need to fill in any spots just dust on clear in those areas and respray flake in that area After your all finished with your flake then just use a good clearcoat and apply your finish to desire shine, you may also wetsand and buff after final clearing Attached is some samples of flake sprayed with this...... you may shipped to the lower 48 states
