........ 1936 FORD ........ We Feel this is Really a Work of ART that you can also Drive and Enjoy... ***Words Can't Describe howGreat this ...Truck Drives and How FUN! I have personally put over300 mileson this truck in the last month !!! The trucks we sell are Driven so we can honestly answer the question.... "how does it drive on the interstate?! This Truck has Been a Pleasure! Very Comfortable!! Built to drive anywhere at 80mph + ! Beautiful! POWERFUL! FAST....! TITLE IS FOR A 1936 FORD READY TO TRANSFER, NO PROBLEMS! BODY: From the start was an extremely solid body Well Done Chopped Top, Chopped 5" Shortened Bed 6" No Channel, Full Leg Room Model A Tail light! Insulated / Sound deadened Roof Very Quit inside, no Rattles! Louvered Custom Roll Pan! Louvered Hood! Perfect Proportions on this Traditional Hot Rod! Suspension: Air Ride Rear w/ Triangular 4 Link Custom Frame Viair Compressor 4" So Cal Drop Axle Rebuilt 1956 Ford Drum Brakes Stops Very Nicely! 16" 1935 Ford Wire Wheels 7.50 x 16 Rear, 6.00 x 16 Front, Firestone Bias Plys Speedway Quick Release Steering Column GM 10 Bolt Rear BED: Spun Gas Tank w/ Leather Belt Straps Lift up Bed with Leather Strap Storage Section to haul Cooler, Chairs and access Air Compressor, Air Bags, Battery etc ....hidden storage section! THE ENGINE /DRIVETRAIN: Rebuilt 350 ci Strong, Nice Oil PSI ! Rebuilt 400 AUTOMATIC Transmission Aluminum Radiator, Runs Very Cool Starts First Crank, Every Time! New Wiring Harness All New Working Gauges Nice Sounding Cam! Lake Headers Wild Exhaust Note ! (listen to in video!) Vintage Speed Deuce Carb Setup, Doesn't Run Rich, Tuned Just Right! Rochester Carbs Electric Fan to Keep things cool at all times! GM HEI INTERIOR: One Words comes to mind...."Detailed" at the same time very Minimal and Hot ROD! Nicely Paded, Comfortable Seats Authentic Aircraft Lap Belts New Gauges ALL New Glass including Side Windows, Roll up like they should! Front Crank out Window New Window Felts, No Rattles Tall Automatic Shifter Working Lights, High Beams, Low Beams Drilled Brake Pedal and Spoon Gas Pedal 12v Accessory Plug In (Phone, GPS, etc) Lots of Leather Details.... ....Door Pull, Door Stops, Column Insulator, and Key Chain Battery Shut off Switch Behind Seat! VERY COMFORTABLE !!! ..... Plenty of BELLY ROOM for us Bigger Guys!!!!
